Hi I use VCDImager to convert .DAT to .MPG and vise versa, but was wondering each time I do this am I loosing quality? Or are the types similar enough that they should be converted with no loss...?
This question has been asked / answered numerous times.
Try doing a search on it. -
Beretta, you could have just answered the question! You don't have to make an ass of yourself. I searched the forums, and I don't want to make it an hour long process. Yes or No. Thats all we want to know!
Why convert Dat to MPEG ! Just rename the file from .dat to .mpeg or use properties plus to do the same. They are basically the same files ..
Converting .dat to .mpeg or vice versa simply involves adding or removing certain special header information attached to the mpeg. The header information is relevant to devices that play the disc as a VCD, but not to computers playing the files directly.
No re-encoding of the MPEG is involved as a result of the conversion, thus there is no quality impact. For editing or CD mastering, though, a .dat should always be converted to an .mpeg using a tool such as VCDGear. -
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>Why convert Dat to MPEG ! Just rename the file from .dat to .mpeg or use properties plus to do the same. They are basically the same files ..</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
They are basically the same, but are different enough that converting from DAT to standard MPEG is definitely a good idea. VCDGear can do this.
There is no loss of quality.
Regards.
Michael Tam
w: Morsels of Evidence -
Make an ass of myself? I informed you that it had been covered before, and thus would be available in a search. I gave you the information that would allow you to look up your answer, and get more than a "yes/no" answer.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
I slightly agree w/ Beretta. People these days look for things using their mouths instead of their eyes more than half of the time.
How to burn 1920x1080 mpg to dvd without loss of quality?
By ABUELLO in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2013, 15:48 -
How to downsize MPG files with least quality loss
By windranger in forum Newbie / General discussionsReplies: 11Last Post: 28th Mar 2012, 15:37 -
DAT/MPG to VOB/MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2011, 06:21 -
MPG editing without quality loss?
By spup345 in forum EditingReplies: 7Last Post: 20th Jan 2010, 17:15 -
Large size difference in mov and mpg, no apparent loss of quality.
By prioryjim in forum Video ConversionReplies: 3Last Post: 20th Dec 2009, 10:19
