I was going to edit the sound track in a Karaoke VCD. Using VCDGear 3.5 to convert the *.dat to *.mpeg, then TMPEnc 2.59 to Demux the mpeg file, I eventually got the *.m1v and *.mpa files. The mpa is the audio file. However, Steinberg WaveLab 3.0 won’t touch it. Cool Edit 2000 did load it up. But the waveform was only a straight line on the screen and there was only noise when I played the loaded file. Renaming the file to mp2 or reloading after saving with a header didn't make any difference.
The same audio file played beautifully with Window Media player 7.
Any help would be greatly appreciated as to how to edit this mpa file and then Mux it back to a mpeg file to be burned as a Karaoke VCD. Thank you.
Results 1 to 1 of 1
Tony
Menu editing after adding audio track
By Instant Martian in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2011, 11:23 -
please recommend tool for editing + adding audio track to video
By lovelove in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 23:10 -
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 09:02 -
Create an uncut composite by editing the audio track
By TRAXX-74 in forum Authoring (DVD)Replies: 3Last Post: 12th Sep 2008, 19:32 -
Editing audio track from 1080i TS captured from DVR
By pulsation in forum AudioReplies: 3Last Post: 27th Oct 2007, 20:34
