When I attempt to open an AVI file in TPMGenc plus 2.5 (2.510.49.157)
I get
file "F:\623\623_1.avi" can not open, or unsupported
When I run AVIcodec I get
F:\623\623_1.avi is incomplete (too small)
Codec is identified as Sony Digital Video
A1 codec PCM
File : 5.76 Gb (1.102 Gb), duration 0:27:07, type AVI, 1 audio stream(s), quality 98 %
Video : 1.72 Gb, 9023 Kbps, 29.970 fps, res. 720*480 (4:3), dvsd = Sony Digital Video, Supported
Audio : 297 Mb, 1536 Kbps, 48000 Hz, 2 chan., 0x1 = PCM, Supported
The file runs in the main concpt encoder ok
What is wrong?
What do I need to do to fix things?
Thanks![]()
It sounds like your missing a codec. The error TMPGenc is reporting indicates it can't read the file. It's also possible the AVI is corrupt. See if you can open the AVI with VirtualDub too.
Impossible to see the future is. The Dark Side clouds everything... -
No it would not open in Virtual Dub
I am running Windows XP
It runs fine in Windows Media Player! Are th XP codecs different?
Where would I get the missing codec from?
I have the following encoders \ codecs that I know of
Encoders Found: 2
[DVenc] [DVCPROenc] VfW: LongName: "Canopus DV Codec for DVBooster Pack (VfW)" Handler=0x63646976/0x43564443 Conf=1 About=1
DX: LongName: "DV Video Encoder (DirectX)" Handler=0x73646976/0x64737664 Conf=0 About=0
Decoders Found: 2
[DVdec] [DVCPROdec] VfW: LongName: "Canopus DV Codec for DVBooster Pack (VfW)" Handler=0x63646976/0x43564443 Conf=1 About=1
DX: LongName: "DV Video Decoder (DirectX)" Handler=0x73646976/0x64737664 Conf=0 About=0
Thanks -
Open the file with GSpot. It should tell you what codecs are in use, and if you have everything installed to properly decode it. Find it in the TOOLS section.
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 11:50 -
avi to ipod conversion incomplete
By millieflower in forum Video ConversionReplies: 1Last Post: 25th Jan 2009, 00:08 -
Incomplete Encoding? (RMVB to AVI)
By Takius in forum ffmpegX general discussionReplies: 3Last Post: 25th Dec 2008, 02:06 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 04:37 -
Error: Sense key=Medium Error. Sense Code=0x73, 0x03.
By Idlewild in forum MacReplies: 14Last Post: 10th Mar 2008, 12:36
