does anyone know how i can cut a m2v file?
Results 1 to 13 of 13
i just tried it but i get an error when i try to edit the video. it says "could not obtain the length of the movie with DirectShow (0x800004001)"
is there any thing else i can do? -
its really hard to cut something using this because it doesnt let you see where your cutting
No, give up....or try this http://www.digital-digest.com/dvd/downloads/mpeg2cut.html
File could just be corrupt. Try to run a disk doctor and/or defrag and pray it fixes your file. Otherwise, as baldrick said, give up.
i dont thin kthe file is corrupt because when i use tmpgenc, it doesnt let me do any cutting with any of my m2v files
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 04:09 -
Cutting a M2V file or editing SINGLE FRAMES of it
By lorix in forum EditingReplies: 3Last Post: 13th Nov 2008, 03:05 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
