  1. I'm trying the "high quality" method for my AVI to DVD conversion, which means encoding video and audio separately.
    I'm currently encoding the video file (m2v) and TMPGEnc is about 25% done but I'm really surprised that my m2v file is already HUGE: 2,2 GB and counting...Is that normal? How am I supposed to burn my DVD if the video file is about 9GB and the WAV file is about 500MB (it's a 50 min. movie)?? Do you think I should continue the conversion or should I stop here to try something else?
    I've got a last question: is it normal that the conversion is so slooooow? I've got a Pentium 4 2.4 GHz and 512 MB DDR Ram and it takes about 12 hours (!!) to encode a 50 minutes movie...I don't do something else while encoding -- except right now because I'm on this forum.
  2. Member SaSi's Avatar
    Jan 2003
    Hellas
    You should probably cancel this encode.
    Before you do actual encodes with Tmpgenc for full movies, select a nice portion of the movie (best if it is exactly 1 minute long) and try different settings with it. You can (practically) extrapolate time and size from the 1 minute clip without waiting for a day.
    On your machine, Tmpgenc should be able to make a good quality encode in less than 5-6 hours, however it all depends on several factors.
    Experiment with VBR settings, selecting a very low bitrate (200-300kbps) for min and 8000kbps for max, play around with the motion estimate method (normal is good quality, you don't really need to go to high-quality unless you select a REALLY low bitrate).
    Don't use any Tmpgenc filters.
    Also, DO a search in VCDHelp.com searching for "Tmpgenc". You will be amazed by the volume of useful info you will find (without waiting for kind souls to respond).
    The more I learn, the more I come to realize how little it is I know.
  3. I followed your advice and cancelled the encode...I found out 45 minutes were already done by wacthing the m2v file. So I had a 2.5 GB file for 45 minutes, is that reasonable? I guess TMPGEnc said 25% only because I used this method: http://dvd-hq.info/Compression.html and I used the CBR option instead of the 2-pass VBR.
    Btw, I read lots of topics about TMPGEnc and I might use the search engine in a wrong way because I rarely find the answers I need. That's why I created this topic.
    When I extract the audio of my AVI file it does something weird: I've got a 1.5 GB WAV file that lasts 2h26 min. with no sound (my movie last 50 min.). When I tried out with VirtualDub I got the right length but a really small file: 45 MB (!)...what's up with that?
  4. I found something that could be of some use for people having the same problem I had: in TMPGEnc, in the Settings tab of your template, select "High quality" instead of "Highest quality" for Motion search precision.
    It saved me 6hrs30 of encoding: I first needed 12 hours to encode a 50 min. movie and now I just need 5hrs30...
  5. Member SaSi's Avatar
    Jan 2003
    Hellas
    Every step you make towards "higher" quality in Motion Search Estimate method will probably double the time it takes to encode (roughly). I have done descent encodes even with the lowest quality setting. For a rather short video with generous bitrate, you don't really need too much effort in doing motion estimation (well, not you, the encoder )
    I would use the "Normal" setting (even the last setting that is marked fast) is good enough. The trick is selecting a good average bitrate and setting the min bitrate to a very low value and the max bitrate to something like 7Mbps. Then do a two pass VBR so that bitrate is allocated in the best possible way. Make a search in the forum for Tmpgenc and how to set the cache for the VBR pass (it speeds things up by 50% or more - or so they say people that have done this).
