I have a tv series which is 30 episodes long. One episode on one vcd. Is there anyway i could put like maybe 5 episodes on one dvd-r? how would i do that?
My process:
1. rip cd with vcdgear.
2. demux the mpg with tmpgenc.
3. encode the mp2 to a 48mhz ac3 with besweet.
4. author the dvd with maestro.
5. burn with nero.
But there is a catch.. Some of the episodes done this way have bluring and blocks at the bottom. They say it is caused by cutting out the commercials in the mpeg. So if you're lucky you can use this methode without trouble to put 8 episodes on a dvd. -
I would use svcdtodvdmpg and then author with ulead moviefactory.
https://www.videohelp.com/guides?tools=&madeby=&formatconversionselect=VCD+to+DVD&ossele...&search=Search -
I was wanting to do this once, but i was told that Mpeg1 files with a framerate of 23.976 could not be put on DVD and that it has to be 29.097.
I think i read somewhere the framerate should be 29,97 but there are programs which you can use to change the framerate.
One would be tmpgenc you can use it to reencoded the mpeg to the right framerate.
I don't know any other programs. But maybe some1 else can help you with that.
Transfering contents from one DVD to another?
By whatever911 in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2012, 12:49 -
transfering VHS to DVD
By Chuck Linn in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2011, 11:11 -
Transfering from 3/4" machine to DVD recorder
By Soundhound in forum Capturing and VCRReplies: 10Last Post: 1st Dec 2009, 00:42 -
Transfering movie to dvd fab
By jrswifey6264 in forum Newbie / General discussionsReplies: 6Last Post: 8th Sep 2008, 18:51 -
Screen jitter when transfering from VHS to DVD
By Corey in forum DVD & Blu-ray RecordersReplies: 10Last Post: 31st May 2007, 18:43
