Wanting to transfer my VHS moments to dvd-r. Some are on regular VHS tapes and some on VHS-C. How can i transfer those to DVD-r? Will those Dazzle video creator units work? i seen 2 different models - 80 & 150. Any help appreciated- thanks
The user comments in the section "capture cards" at left was very helpful to me on my purchase of a capture card. I chose the Adaptec PCI. Dazzle may be great for you, don't know. Keep in mind the resolution you can live with, not wish for.
You will need a anolog to digitial converter. Dazzle does make one, some digitial camcorders also have this option, if you had a friend that would let you use it. Hook the vcr to converter and the converter to the pc. Record away.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
