hi
i've been converting mp3s with besweet to ac3 for use in dvds. the problem is that the ac3 files have crakles and pops while the mp3 files didnt have these problems.
by the way i used the guide from this site for besweet.
thanks for any help given.
I Guess that samples are clipped!!! Maybe you should turn off BOOST???
and use normalize instead...
'HAG -
if you go from mp3 to wav and then from wav to ac3 these problems should be sorted.
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 18:57 -
MP3 to AC3 Possible?
By skorpinok in forum AudioReplies: 2Last Post: 29th Aug 2011, 14:39 -
mp3 -> ac3
By cL0N31 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2009, 22:26 -
mp3 to ac3
By volam in forum AudioReplies: 3Last Post: 24th Feb 2008, 07:44 -
XVID AC3 TO MP3 Conversion problem help!
By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 15:55
