What program will author "DVD compliant" files encoded with Main Concept to DVD video ts files. Tried DVDit LE, no audio. Spruceup, no. UL Mov Fact 1, no. Pinnacle Expression, no. B's DVD, ?
Confused....................harrymj3
Are you sure the files are dvd compliant?
What are your settings in mainconcept?
What is the error msgs in all tools?
Have you tried demultiplex the files and import the video and audio separate? -
1.I am using the default settings with only the bitrate lowered to 4200.
2.DVD,720x480,VBR,PCM48000 16 bit
3.I haven't coppied the error messages and that computer is tied up right now but I'll ck it again later and get them for you. Spruceup needs seperate files. B's DVD just hung, after an hour I hit ctl, alt, del and it said program not responding. UMF1 won't accept pcm audio. DVDit LE went through all the motions and I figured ah ha I've got it but it recorded no audio, only video. Expression said program needed to close as soon as I moved to the preview window.
4.No I haven't tried demultiplex. I wanted to see if it would work in any program without taking that step. I tried the mpg2 w/mp2 setting for encoding but had a crash right away, about 3 min into encoding.
Thanks for your intrest. ........... harrymj3 -
DVD Architect by Sonic Foundry
Im postive it works with main conceptes cause Vegas Video uses MC & its allso a Sonic Foundry product.
https://www.videohelp.com/forum/viewtopic.php?t=149219&highlight="Man who walk through airport turnstile backwards
going to Bangkok."
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 20:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 7th Aug 2010, 00:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 17:19 -
encoding and dvd authering help plz
By lucid_dreams in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2008, 17:05 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 16:22
