When capturing Audio at PCM standard the audio recorded, not previewed, had allot of distortion. By this I mean crackle which is as if the record volume is set too high. (Similar to when you set the record volume too high on a and old cassette deck). I have changed the volume slider in Windows and on the volume meter in Virtualdub. Nothing seems to make a difference. The only thing that removes the crackle is recording in MP3 format.
Closed Thread
Can you check the sampling rate at which you capture sound? I suspect that you are capturing mp3 at a different sample rate (perhaps because your MP3 codecs only support these). For example, perhaps you are capturing PCM at 48kHz and MP3 at 44.1kHz.
Try recording audio (from a cassete player or external DVD player) at variable sampling rates. It may be that the audio card has problems.
BTW, are you using a sound card? Or are you using the onboard AC97 codec chip?The more I learn, the more I come to realize how little it is I know.
I think you have sent me in the right direction. I'm not to sure with sampling rates etc. BUT. If I chose Sony Hi 8 from the drop D List all works well. (This is OK as the source is mono). So I am going to try different presets and change the format and rates from their drop D Lists.
I have the sound going directly from the VCR to Sound card. So as a newbie I geuss I'm using the Card not AC97, which I think is on the video card right?
BTW, any idea why I have to keep going into ULEAD to change the format of the signal from NTSC to PAL. Why would it keep defaulting to NTSC? How can I change from VirtualDub. (I want to keep away from ULEAD, it has wasted so much of my time)
Ta for your help.
Don't double post -- your thread is continued here :::
https://www.videohelp.com/forum/viewtopic.php?t=153514
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
PCM audio on BluRay
By ecc in forum AudioReplies: 2Last Post: 21st Jan 2010, 09:37 -
Vob2mpg PCM audio
By schematic2 in forum DVD RippingReplies: 3Last Post: 24th Feb 2009, 12:33 -
is LPCM the same as PCM, for audio?
By runLoganrun in forum Newbie / General discussionsReplies: 14Last Post: 6th Dec 2008, 20:37 -
PCM audio in MENCODER
By zepperdude in forum AudioReplies: 1Last Post: 16th Oct 2008, 22:56
