I have searched and cannot find a clear answer to this.
For instance, using emulators via Retroarch on my CFW PS3. Setting
the Display in RA to 1920x1080 (1080p) will upscale the (in this case 8/16-bit) retro games allowing you to see even more of the fine details.
So my question is basically do Blu-Ray players actually upscale from 480p to 1080p as in re-drawing or do they simply stretch the image?
Couple of answers:
1. DVD, Bluray players (and UHD/4K BD players) can upscale, depending on the settings. They rarely upscale beyond their native default resolution, just upscaling from smaller to normal
2. Those settings could be set to: no upscaling (w/ pillar/letterboxing), zoom, stretch, etc.
3. TVs do it too, so choose which way looks best: upscale in player + leave alone at TV vs. leave alone in player + upscale in TV vs. leave it all alone and watch native size (no interpolation there). Do NOT upscale twice.
4. Upscaling = interpolation = guessing no matter which method is tried ("redrawing"?, "stretching").
5. You NEVER, NEVER, NEVER get MORE detail when upscaling, always less (because interpolation), but depending on the kind of guess and the strength of local contrast sharpening, it may sometimes appear to the unaware as if it had more detail.
My assumption when hearing about stretching is that the aspect ratio changes (squares become rectangles or vice-versa), but this may not be how you are referring to this. Regardless, it is still guessing and redrawing whether proportional or not.
Try all the options and use what looks best to you.
Hope that helps,
Scott -
see this Wikipedia - https://en.wikipedia.org/wiki/Video_scaler#Upscaling.2FUpconverting_DVD
and this here - https://www.makeuseof.com/tag/upscaling-how-does-it-work-and-is-it-worth-it/Last edited by october262; 22nd Jul 2021 at 23:56.
Thanks for the information and links guys.
The default settings I use look very good on my HDTV and Blu-Ray player when playing DVD's. I just wanted some information about how these things work.
Again, thank you both.
Upscale 4:3 interlaced DVD's to Blu-ray compatibility?
By jedi55 in forum RestorationReplies: 20Last Post: 21st Jul 2021, 04:37 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 12:02 -
Do Any Blu-ray Players have Sony X1 EXTREME CHIP?
By KermitJ in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Jan 2020, 12:09 -
Bluray players that will play a processed Blu-ray?
By LloydS in forum DVD & Blu-ray PlayersReplies: 13Last Post: 21st Mar 2019, 21:57 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 07:32
