I have a HP Notebook - 15-f272wm.
Video Graphics: Intel HD Graphics
Microprocessor: IntelŪ PentiumŪ N3540 with Intel HD Graphics (2.16 GHz, up to 2.66 GHz, 2 MB cache, 4 cores)
RAM Memory: 4 GB
Hard Drive: 500GB
Hi,
download potplayer for your system. I believe your system is 64bit so install 64 bit. During installation it will ask you to 1. download additional codec 2. Detects HW and SW 3. Run potplayer. Download it. Check all. And everything should be fine. If you are planing to play 4k videos and something is wrong, that is because your graphics card.
But dont worry, there is something can helps you. Go to preference (F5) open filter control, then open tab OpenCodec and in first line enable Decoder intel QuickSync. Which is feature you processor should support. Restart potplayer (possibly it is not needed but to be sure it is o.k.) You can also set in playback - playback settings - priority to high or what you want. In such changes you for sure dont need to restart potplayer.
You can experiment with video - video renderer to check which is for you most suitable (lowest processor consumption and picture quality) You can check power consumption in windows, or press tab in potplayer to see usage of cpu and gpu.
But if I were you I believe in Potplayer default settings. When anything goes wrong, press F5 and in bottom left press initialize potplayer.
Bernix -
Chibi,
even if it is true about PowerDVD, it is not free and cost 50 bucks. But seriously I doubt that is true about PowerDVD vs Potplayer. Just read some post made by user that suggested it.
Just read minimum requirements for PowerDVD https://www.cyberlink.com/products/powerdvd-ultra/spec_en_EU.html?&r=1 it doesn't met your specs.
BernixLast edited by Bernix; 18th Oct 2017 at 10:24.
PotPlayer (64-bit) updated and lost all my settings!!!
By Balema in forum Software PlayingReplies: 10Last Post: 8th Feb 2017, 05:39 -
HEVC x265 potplayer settings
By Annonboy777 in forum Software PlayingReplies: 0Last Post: 13th Jan 2017, 06:21 -
PotPlayer settings
By Montmorency in forum Newbie / General discussionsReplies: 12Last Post: 1st Nov 2014, 02:04 -
PotPlayer Subtitle settings
By Zyph in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2014, 01:03 -
PotPlayer - How to restore settings via .ini / .reg
By tuco76 in forum Software PlayingReplies: 6Last Post: 2nd Oct 2014, 08:30
