I was wondering which codec-pack is the best to install on your Windows XP Machine with SP2.
If a perticular pack isnt listed, then feel free to tell everyone.
Results 1 to 10 of 10
There is no such as things as a best codec pack, or even a good codec pack. Most codec packs contain clashes and contradictions, half-arsed modifications to the original installers, and end up causing you more grief than good because there is not way to work out why a particular video or audio codec doesn't work.
If you wan't the missing option on your poll, it is "I would never install a codec pack - I value my machine too much"
Use soemthing like g-spot or avicodec when something wont play. They will tell you what you need. Download and install just that codec, and move on. Codec packs are for script kiddies who download indiscriminantly and don't care how screwed their machine is until it all stops. Then they scream "f&*king microsoft" and reinstall XP. Something they wouldn't have to do if they looked after their toys in the first place.Read my blog here.
Whenever I rebuild I start with Nimo 5.0 and add any other codecs I might need manually if necessary. Be wary though as some Codec packs can conflict with other codecs installed. It is best to install a Codec pack on a freshly installed OS.
My idea coincides with ROFs - If you have a virgin box, and the ones creating the codec pack has anything behind their forehead bone, in theory, that would get you a good multi media system. Now, I don't trust codec pack "groups", and don't find installing (manually) a new codec once in a very long while that much of a burden, so I'd never recommend any codec pack.
Just asking that question here is like asking Hells Angels what's the best Jap bike. Just that we're much nicer than HA
/Mats -
So Insted of installing codec packs, i just install each codec individually?.
But there are many divx codecs out there. i am just confused which one to use for what?. -
Generally, when a new version of a codec is released (like DivX6) it's backwards compatible, so, for instance, you just need one DivX codec to handle playback of all DivX encoded material, be it DivX 4, 5 or 6.Originally Posted by nirbhayn
/Mats
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 12:45 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 6Last Post: 2nd Feb 2012, 22:39 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 1Last Post: 27th Jan 2012, 14:44 -
K lite codec pack
By Pumkinhead in forum Newbie / General discussionsReplies: 14Last Post: 26th Oct 2010, 14:12 -
Codec Pack selection?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2007, 11:50
