INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Login:   Username:  Password:   Log me on automatically
Register I forgot my password I forgot my username Resend the activation key
hi 8 tapes to dvd ?? help
Forum Index -> Video -> Camcorders (DV/HDV/AVCHD) Printer-friendly version
Reply to topic
Author Message
daviey boy
Member
Post Posted: Nov 05, 2009 05:49 Posts Comp View users profile Send private message Reply with quote
hello im a total noob to this so here goes,, i have searched the net but cant seem to find an exact answer ? i have a medion cam corder 80324 which has a built in digital signal processor i guess this means it will change to mpeg or similar file ?.. it has s video 4 pin port and also a av output with a scart that goes to tv . my problem is im trying to get from the tape to dvd using my computer , i have firewire ports included on my pc . can i buy such a lead that goes from svid to firwire or av to firewire ? would this work as the signal has been converted with the processor on the cam corder or am i thinkin wrong and can i even buy such a lead ?? or do i need to run the cam into something like moviebox dv or dazzle . please help thanks
i have looked into buying a dvd recorder and am aware of this option but i wanto be able to edit an author
Nelson37
Member
Post Posted: Nov 05, 2009 12:14 Posts Comp View users profile Send private message Reply with quote
If the camera does not have firewire out, then you will need some sort of capture device. Many ways to do this, the DVD recorder is probably easiest and the output can be edited on the PC.
edDV
Member
Post Posted: Nov 05, 2009 12:29 Posts Comp View users profile Send private message Reply with quote
You will need an analog S-Video to DV converter. Among the recommended options...
1. A MiniDV or Digital8 camcorder with "analog pass through" to DV feature.
2. Canopus ADVC converter (serveral models)
3. ADS Pyro DV converter
The DV Moviebox and older Sony converters are not recommended.
Or, you can capture S-Video to a DVD recorder or conventional computer capture card.
Also, some Digital8 camcorders will play Video8 or Hi8 analog tapes with DV output over Firewire.
_________________
http://www.kiva.org/about
lordsmurf
Video Restorer
Post Posted: Nov 05, 2009 15:17 Posts Comp View users profile Send private message Reply with quote
You can play from the camera into a DVD recorder or any capture card. DV not required (and not suggested, to be honest).
_________________
digitalFAQ.com -- Help with VHS to DVD, DVD recorders, other video/photo issues.
NoMoreCoasters.com -- How to avoid bad burns, how to find the best blank DVDs.
Bjs
RoadKill
Post Posted: Nov 06, 2009 00:24 Posts Comp View users profile Send private message Reply with quote
Dazzle Video Creator Plus
Video inputs: Composite video (RCA), S-Video (mini-DIN)
Audio inputs: Stereo audio (RCA x2)
PC connection: Hi-Speed USB 2.0
daviey boy
Member
Post Posted: Nov 06, 2009 06:22 Posts Comp View users profile Send private message Reply with quote
thanks .. what about roxio's easy vhs to dvd ?? looks simple an cheap enuff ?? although it use's a usb ?/ not to sure if thats a bad thing ??
edDV
Member
Post Posted: Nov 06, 2009 10:49 Posts Comp View users profile Send private message Reply with quote
What would you use for a capture device? Hi8 camcorders don't have usb. They are analog S-video out.
_________________
daviey boy
Member
Post Posted: Nov 09, 2009 03:27 Posts Comp View users profile Send private message Reply with quote
no it has audio to usb check this http://www.roxio.co.uk/eng/products/easy-vhs-to-dvd/standard/over ... 4wodjmKFLw
it just plugs into the av jack on my cam corder ?/
but does usb reduce quality
daviey boy
Member
Post Posted: Nov 09, 2009 03:47 Posts Comp View users profile Send private message Reply with quote
reviews arent over whelming for this product it seems !!
kimco52
Member
Post Posted: Nov 09, 2009 05:28 Posts Comp View users profile Send private message Reply with quote
I use the ADS Pyro for analog sources. Works great. When not capturing from those devices, I use it to output the an external monitor while working in Premiere. Whatever I am playing/scrubbing, then also goes to the external video monitor.
Since my computer has 3 Firewire inputs, I connect my digital sources directly to one of the other ports.
Reply to topic All times are GMT - 6 Hours
Forum Index -> Video -> Camcorders (DV/HDV/AVCHD) Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
