| Author |
Message |
Abas-Avara Member
Maybe I can't find it, but I think it would be a great feauture to bookmark a topic.
So you found a great topic with lots of usefull information and that you can bookmark it so you can look back later (when you forget it for example).
What do you guys think?
_________________ The flag once raised will never fall!
AlanHK Member
Bookmark in your browser.
I've got a dozen threads here bookmarked for exactly that reason.
hech54 CONFUSED
I just post in ones I'm interested in....something simple...that way you can go to "View Your Posts" and go down the list.
_________________
Abas-Avara Member
Bookmarking in the browser is a option, but it's more hassle and takes longer time. If you go to another computer or after a reinstall, it dissappears (I know the tricks for saving but not everyone).
but with this option you just log in and view your bookmarked topics.
It isn't such a big deal but it would be easier for everyone.
I've seen in more forums the option for bookmarking.
AlanHK Member
My bookmark list has got links I've saved for more than 10 years... backed up and copied innumerable times.
I stash copies on most DVDs I burn.
lordsmurf Video Restorer
Use XMARKS, to sync multi computers.
_________________ digitalFAQ.com -- Help with VHS to DVD, DVD recorders, other video/photo issues.
NoMoreCoasters.com -- How to avoid bad burns, how to find the best blank DVDs.
guns1inger Member
| lordsmurf wrote: |
| Use XMARKS, to sync multi computers. |
Second that. Just installed Windows 7 on a dual boot, installed Xmarks, and all my bookmarks are back again. I also have then sync'd with my laptop.
_________________ The views expressed in this post are mine alone, unless plagiarised from others
Read my new blog here
