INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Login:   Username:  Password:   Log me on automatically
Register I forgot my password I forgot my username Resend the activation key
FairUse Wizard error
Forum Index -> Video -> DVD Ripping Printer-friendly version
Reply to topic
Author Message
dudeman316
Member
Post Posted: Jul 01, 2009 07:13 Posts Comp View users profile Send private message Reply with quote
I am trying to transcode some of my movies to h246 avi's using fairuse wizard & it does take a long time, but when it gets to the part where VirtualDub is used, I get an error message & it crashes, left with 2 files one is sound & other is video. Any clue why I am getting this error & any suggestions as to what program I could use to mux the sound & video together without losing the quality?
this is what the error log gave me:
AppName: virtualdubmod.exe AppVer: 1.5.4.0 ModName: ffdshow.ax
ModVer: 1.0.3.1023 Offset: 0015e0c7
_________________
Father knows best.
RabidDog
Old B.
Post Posted: Jul 02, 2009 19:42 Posts Comp View users profile Send private message Reply with quote
Clean out, re-download, re-install.
Reseat all yo memory chips.
RUn your PC at stock voltages/stock speeds.
half completed files are no good to you, just delete them.
x264 IS good but on a P4 its not worth (imo), the time to encode over xvid insane quality / dvix purest quality
_________________
The electronic components of the power part adopted a lot of Rubycons.
dudeman316
Member
Post Posted: Jul 15, 2009 16:21 Posts Comp View users profile Send private message Reply with quote
im done with fairuse wizard, I get much better results with Handbrake. JUst one question, which audio is better AC3 or AAC?
I do play back through a surround sound system not sure if AAC is surround sound
thanks
_________________
Father knows best.
branch
Member
Post Posted: Jul 21, 2009 12:58 Posts Comp View users profile Send private message Reply with quote
How do you set "insane quality" in Fairuse Wizard?
There is a speed/quality slider i moved to quality, but there is still visible pixleation around letters in the final avi
Reply to topic All times are GMT - 6 Hours
Forum Index -> Video -> DVD Ripping Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
