INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Login:   Username:  Password:   Log me on automatically
Register I forgot my password I forgot my username Resend the activation key
Pls need help on how to make Samsung DVD-HR733/775/777 region free
Forum Index -> Hardware -> DVD Recorders Printer-friendly version
Reply to topic
Author Message
noiq
Member
Post Posted: Mar 22, 2009 06:56 Posts View users profile Send private message Reply with quote
sad.gif Well, I have tried the posted hacks...unfortunately without any success. I have just purchased this Samsung HDD and DVD recorder. It is set for region 4 Australia and I need it region free.
The hacks I am referring to were posted by rolfal on May 11 2008 and by PitKing on August 11 2008.
Thanks to all the wonderful, techsavvy people out there.
Krispy Kritter
Member
Post Posted: Mar 23, 2009 14:04 Posts Comp View users profile Send private message Reply with quote
All the hacks listed for those models appear to be the same. However, the hacks don't always work on all versions (ie: US or international) of a player. Also, the firmware often varies between models with newer versions often being locked by the manufacturer to prevent the codes from working.
_________________
Google is your Friend
Jickzy
Member
Post Posted: Apr 14, 2009 02:49 Posts View users profile Send private message Reply with quote
Hi there,
Similar situation here; I have an HR-773 Region 4 and have tried out the posted hacks. Not very savvy with these things, but didn't have any luck.
Just wondering about the part where you have to press "Repeat" and then enter your code.
When I press "Repeat" it brings up a menu that includes the Timer function for the DVD recorder. Would this menu screen be the right one to have up when trying to input the digit hack code? This didn't work for me. Am I missing something? question.gif
Another hack version said to go to "Menu" then "Settings". There is no "Settings" on the DVD menu, only "Setup". Would this be where to go? (The only "Settings" I found was for the TV remote!).
KBeee
Member
Post Posted: Apr 14, 2009 11:46 Posts Comp View users profile Send private message Reply with quote
Many Samsung hacks are merely cut 'n pastes of a hack that worked for 1 model, that probably won't work on other models.
Your "Press REPEAT button" is a classic case. On some Samsung DVD Players remote controls there is a REPEAT button that is for DVD Repeat, which the hack needs, while on some Samsung remotes for DVD Rercorders the REPEAT button is for Timer Repeat, which is useless for the hack. Of course firmware and even remote controls can change over the lifetime of a model, and maybe at 1 time the "Use remote control
Turn on player (without a DVD within)
Press "Repeat"
Enter numbers "5" "7" "5" "3" "8"
The current region code will be displayed in the upper right hand corner.
Press "9" for region free (multi region) - (don't wait too long)
Open the tray and close it again." hack DID work, but I've never figured out how they managed to press the non-existant REPEAT button.
jman98
Member
Post Posted: Apr 14, 2009 12:07 Posts Comp View users profile Send private message Reply with quote
Be warned that for a variety of reasons such as hardware changes during production, incompetence by the person posting (they leave out a key step or list something incorrectly), etc. that hacks that worked in the past may not work any more. Also note that it seems to many of us here that ALL (as in 100%) currently sold Samsung DVD players appear to be region locked and cannot be hacked at this. Your chance of having a hack work probably depends heavily on how old your model is. Anything "just purchased" probably can't be hacked, but let us know if you beat the odds.
Jickzy
Member
Post Posted: Apr 15, 2009 01:18 Posts View users profile Send private message Reply with quote
Thanks for both these replies. The recorder has just been bought so I guess it is unlikely that anything will work. A real shame when your old DVDs are just sitting there! It's good to have that "Repeat" issue cleared up anyhow.
Thanks again.
andario
Member
Post Posted: Apr 15, 2009 04:56 Posts Comp View users profile Send private message Reply with quote
I got a hack working on my sisters DVD-HR773, this is how i did it... i'm from NZ and the region is 4 just like in Aussie.
Updated firmware from the samsung website, the downloaded file had 775 but worked fine. (Dunno if this is needed or not for the hack).
Turn on player with no disc in drive.
Press either menu or repeat to bring up the menu (both worked, the code worked no matter how i got to the menu).
Enter your region code eg 76884 (region 4 code).
A number appears in the top right which is your current region, press 9 for region free
Open disc drive with remote.
Wait a lil then turn off the player.
I tried turning off straight after pressing 9 but it didn't save the region, but when i used the open disc method it did save. While hunting the net for a method i found these region codes for samsung:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
I've only confirmed the region 4 code.
andario
Member
Post Posted: Apr 15, 2009 05:11 Posts Comp View users profile Send private message Reply with quote
57538 also popped up as a region 2 code for certain models.
sabbath69
Member
Post Posted: May 16, 2009 20:05 Posts Comp View users profile Send private message Reply with quote
Many thanks to andario, as I can confirm that his code for Region4 certainly works.
I just purchased this unit new yesterday.
Tried the steps he outlined entered the 76884, and the code showed up, changed it to 9, followed the other steps, powered back on an Woo Hoo!
Many thanks.
asher1101
Member
Post Posted: Jun 24, 2009 03:14 Posts Comp View users profile Send private message Reply with quote
andario wrote:
I got a hack working on DVD-HR773... from NZ and the region is 4. ... 775 worked fine.
Thanks a lot for andario, this hack works for DVD-HR775 for region 5 as well, but with a slight changes:
Press repeat to bring up the menu. Enter the SYSTEM submenu. If not work try SYSTEM\VIDEO submenu.
Enter your region code eg 53814 (region 5 code).
A number (eg5) appears in the top right which is your current region, press 9 for region free, press OK on remote
Wait a little, then turn off the player.
KBeee
Member
Post Posted: Jun 24, 2009 05:06 Posts Comp View users profile Send private message Reply with quote
Thank you very much andario.
After giving up on a Samsung SH855, your hack (with a little modification) worked.
For the Samssung SH855M (Region 2 UK)
1. Turn on without disk in drive
2. Press "MENU"
3. Press 57538 (Number 2 comes up in top right hand of menu screen)
4. Press 9 (Number 2 changes to 9)
5. Open disk tray
6. Close disk tray
7. Turn off player
I found I had to close the disk tray before turning off to make the new region stick.
73n5
Member
Post Posted: Oct 15, 2009 23:30 Posts Comp View users profile Send private message Reply with quote
2. Press "MENU"
5. Open disk tray
6. Close disk tray
7. Turn off player
This just worked like a charm for me, on my new Samsung DVD-HR773A. I'm in Denmark, so it's the same region.
And I was just about to give up too...
corell
Member
Post Posted: Nov 02, 2009 10:15 Posts Comp View users profile Send private message Reply with quote
2. Press "MENU"
5. Open disk tray
6. Close disk tray
7. Turn off player
I got mine in Denmark too - changed it to "region" 9, but for some reason, when trying to watch a region 1 dvd, it shows on my tv in black and white instead of being in colour... Any ideas?
jman98
Member
Post Posted: Nov 02, 2009 10:42 Posts Comp View users profile Send private message Reply with quote
Try to change the video output setting on the DVD player to PAL. If there is no option to set the video output, you may not be able to fix this.
corell
Member
Post Posted: Nov 02, 2009 10:52 Posts Comp View users profile Send private message Reply with quote
There is no video output setting i can find.. Thanks anyway.
Reply to topic All times are GMT - 6 Hours
Forum Index -> Hardware -> DVD Recorders Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
