INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Login:   Username:  Password:   Log me on automatically
Register I forgot my password I forgot my username Resend the activation key
Distortion in FCP
Forum Index -> Video -> Mac Printer-friendly version
Reply to topic
Author Message
Daniel Corcoran
Member
Post Posted: Jun 26, 2008 03:43 Posts Comp View users profile Send private message Reply with quote
Hi'ya
I'm working a project at moment and just wanted some clarification on a issue I'm having. As I capture all my footage and view it there are horizontal lines and slight distortion on the footage, but when I'm watching the footage through the camera it's 100% clear, only when I'm finished capturing it the problem occurs, I've also watched the footage in QT files on the external HD and it seems to be fine! Is this a simple capture setting problem, or will it be ok after rendering all the footage together, I'm sure its a simple problem, the footage is DVCAM. I just haven't come across it in the past, any help would be greatly appreciated.
I've tried DVPal, DVPal Anamorphic, I've also tried de-interlacing the footage- doesn't get rid of the problem! To describe the problem a little bit more detailed- its like a few waves of lines flash across the viewer every few secs and I've noticed that it happens at exactly the same time on the time code! So it’s a capture problem.
Cheers
Daniel
Herve
Member
Post Posted: Jun 26, 2008 05:32 Posts Comp View users profile Send private message Reply with quote
do you have screenshot?
bye
_________________
PM G4 MDD 867bipro (OS Tiger+Leo) - MacMini intel (OS Tiger+Leo) - A soft for DV, DVD-Video, HD files (AVCHD/Tod/Sanyo): http://www.movieconverter-studio.com/ version 1.53 ( 2009/10/02 )
Daniel Corcoran
Member
Post Posted: Jun 26, 2008 08:23 Posts Comp View users profile Send private message Reply with quote
Hi, no I cant get a screenshot because it doesn't show up when I go through it frame by frame, only when its being played back in realtime,
terryj
Member
Post Posted: Jun 26, 2008 11:21 Posts Comp View users profile Send private message Reply with quote
since it occurs at the same spot on the DVCAM tape everytime,
it could actually be a burr in the DVCAM tape itself.
Easy way to test: try importing another DVCAM tape's footage.
IF the other tape's footage comes in fine,then it's the tape.
heck, for that matter, if the original's tape only has one bad spot,
and the rest imports fine, then it IS the tape.
To get a screen shot of the footage as it captures in FCP, use
Capture Me. (google it, or search versiontracker.com)
_________________
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Daniel Corcoran
Member
Post Posted: Jun 27, 2008 03:12 Posts Comp View users profile Send private message Reply with quote
Its definitely not a tape issue- I've played it back on other monitors and no problem, it only shows up on my Mac!! And as mentioned a screenshot wouldn't help as I cant stop the footage on the right frame where the lines are running through it!
terryj
Member
Post Posted: Jun 27, 2008 08:49 Posts Comp View users profile Send private message Reply with quote
ok, let's go through this again:
1. You say you preview on the camera and it is fine.
2. You say you convert to QT files on an external disc and it is fine.
3. You say you capture it to the (please clarify here) and it isn't fine.
IF you are capturing to the INTERNAL HD, which is the same as your boot HD
( in the MBP in your computer details) then yes, this would be a problem.
Try capturing it to the external FW drive, and see if the results are the same.
However, if you ARE capturing to an EXTERNAL DRIVE and the files
are distorted there, take it in steps.
1. Try replacing the FW cable to the drive
( sometimes it really is that simple)
2. Run Disc Utility and try Repairing the External Drive
( could be after several captures, the Volume bitmap needs repair)
3. Use another Firewire drive to try a capture and see if the issue persists ( this will rule out the FW bus mechanism on the external drive)
post back and let us know how things go....
_________________
Urban Mac User
Daniel Corcoran
Member
Post Posted: Jun 27, 2008 10:01 Posts Comp View users profile Send private message Reply with quote
I know its not a capture problem as I've noticed the same problems when I play back video files that I ripped off other DVD's, again once on the timeline the distorted lines appear. I'm going to trash my preferences and hopefully this will help
edDV
Member
Post Posted: Jun 27, 2008 14:58 Posts Comp View users profile Send private message Reply with quote
Is this basic interlace line spit during motion on a progressive computer monitor? If so, nothing is wrong.
Is this different than any other camcorder video played to your Mac?
A simple frame cap showing the issue would get us started.
_________________
http://www.kiva.org/about
Reply to topic All times are GMT - 6 Hours
Forum Index -> Video -> Mac Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
Replay Media Catcher lets you record ANY streaming video and save on your computer! More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
