INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Search all forums or this forum: Advanced search
YouTube accepts FLV!
Forum Index -> Video -> Video Conversion Printer-friendly version
Reply to topic
Author Message
Kargo
Member
Post Posted: Dec 29, 2007 15:38 Posts Comp View users profile Send private message Reply with quote
Today I accidently uploaded an FLV file to YouTube instead of a WMV and I couldnt believe that it actually worked and the video showed perfectly!
was this likely to be a one off FLV upload or have any of you guys also been able to upload FLV files.
and also is it likely that my video will be removed as its a FLV file?
DB83
Member
Post Posted: Dec 29, 2007 16:13 Posts Comp View users profile Send private message Reply with quote
why should they remove it ?
Any file uploaded to Youtube is actually converted to the flv format before it is broadcast.
hech54
CONFUSED
Post Posted: Dec 29, 2007 16:35 Posts Comp View users profile Send private message Reply with quote
I normally convert my vids to FLV with Riva FLV Encoder before uploading to YouTube. It wasn't a one off.
_________________
mohnitor
Member
Post Posted: Dec 29, 2007 16:45 Posts Comp View users profile Send private message Reply with quote
Yep, you can upload flv. But I guess, they still convert it in an automatic process - no matter what format it is.
Why donīt you download the YouTube flv and compare it with your original file on your HD ?
I noticed that all of my uploaded flv files are converted by YouTube. But as I upload 640x480, 2 Mbps - it doesnīt really matters. They look nice.
ricardouk
Member
Post Posted: Dec 29, 2007 18:21 Posts Comp View users profile Send private message Reply with quote
if the bitrate is under 350 it wont be converted
this has been discussed here for a while
http://forum.videohelp.com/topic336882.html
_________________
I love it when a plan comes together!
Ricardo Santos
vhelp
..Semi Neutral..
Post Posted: Dec 29, 2007 20:37 Posts Comp View users profile Send private message Reply with quote
yeah.. if you encode to FLV, (sorensen format) try and keep the bitrate under 350k.
But do not aim for 350k and stop. Try and aim between 346k to 348k but don't go any
higher. The reason is because there are other things going on, on youtube's side though
its mostly on account of the metadata injection which might bloat a few extra bits past
the 350k mark. So its important to leave a little headroom for youtube's metadata injection
and you should be safe with < 350k w/out further bloating.
In using the above notes as a guideline, I was able to upload many videos that are under
the 350k max by a 'k' or too, and no sign of youtube over bloating them
If you use a regular flv encoder, a one pass is ok, but for optimum quality and size, it is
criticle to use a 2-pass encoding routine. SFAIK, mencoder and ffmpeg offer the 2-pass
encoding option. And, couple that with some pre-prep (ad'tnl NR) filters that should help
to bring down the bitrate under 350k (346k-348k) mark. Course, as with any video encoding
project, your mileage may vary.
Good luck,
_________________
VHELP's - Sample Clips [last: 12.29.06],
my YouTube videos
ShayneBabe2009
Member
Post Posted: Jun 30, 2008 14:53 Posts Comp View users profile Send private message Reply with quote
You Tube doesn't seem to take my .flv files. Why would that be??? I'm trying to upload them as the flv format but they aren't videos. They're just songs I found on the internet. Any help??
Reply to topic All times are GMT - 6 Hours
Forum Index -> Video -> Video Conversion Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
About   Advertise   Forum Archive   RSS Feeds   Statistics
