Hi, all. I tried making a DVD from a couple *.mov (MPEG-4) files with Devede, and it worked great! Unfortunately, the audio from the original files is a little flaky, so I wanted to dynamically compress it. To accomplish this task in Windows, I'd extract the audio from the *.mov (MPEG-4) files, compress it, then recombine the original video with the new audio during the DVD (MPEG-2) encoding process. In Ubuntu, however, I have no idea how to do this.
So, let's recap:
1. How do I extract *.wav audio from a *.mov (MPEG-4) file in Ubuntu? <--this question is the most important
2. Is it possible to reincorporate a *.wav audio source into a *.mov (MPEG-4) file without re-encoding the video? If so, how?
3. If not, what's an alternative to Devede which allows me to author low-bitrate DVDs out of separate audio and video files?
Thanks in advance for any help!
--Ben
hurtstotalktoyou
Hi Ben,
I'm sorry it hurts you to talk to me, I'll keep it brief :-b. Avidemux should theoretically do what you want, if it will open your .movs you can use it to convert to MPEG-2 and filter your Audio all at the same time. I actually use Virtualbox in Gutsy with a XP install for this kind of thing myself. Linux is phenomenal but IMHO it has a long way to go to handle the kinds of tasks you're talking about as well as Windows. -
Besides AviDemux -
CAUTION
**I'm not afraid of the command line
#2 -
#1 -Code:mencoder movie.mov -ovc copy -oac pcm -o movie.pcm.mov
To extract the audio file to wav format
This make mplayer play back the video file without outputting the video (-vo null) nor decoding the video (-vc null), and dump the audio file to a wav file titled audiodump.wav (-ao pcm:fast). This wav file will have the same sample rate as the original.Code:mplayer yourmovie.mov -vo null -vc null -ao pcm:fast
You can then take this wav file and edit it with SoX, Audacity, Gnome Wave Cleaner, Sweep, ReZound, or what ever you choose. Then encode to ac3 with ffmpeg or aften.
This has ffmpeg take the input file audio.wav (-i audio.wav) and encode it to 2 channel (-ac 2) ac3 (-acodec ac3) at a bitrate of 224k (-ab 224K) with a sample rate of 48000 (-ar 48000).Code:ffmpeg -i audio.wav -ab 224k -ar 48000 -ac 2 -acodec ac3 audio.ac3
Aften will encode audio.wav to audio.ac3 at a bitrate of 192k, keeping the same input channel format and sample rate.Code:aften -b 192 audio.wav audio.ac3
#3 - Most will only take m2v + ac3/wav/mp2 or mpg files, not many are all in one apps like DeVeDe
DVDStyler
QDVDAuthor
tovid (check ToDisc, neat fading motion menus)
and about 100 others.
MuxMan works just fine through Wine, as does TMPGenc, HCEnc, avisynth, and the DG* programs.
How can I extract mp3 audio from .mov container without re-encoding?
By Danteism in forum MacReplies: 16Last Post: 3rd Jul 2010, 04:11 -
Extract Audio from XviD MPEG-4 video
By MI6 in forum AudioReplies: 2Last Post: 3rd Jan 2009, 05:58 -
How to extract video MPEG-2 from DVD?
By fvisagie in forum DVD RippingReplies: 2Last Post: 6th Oct 2008, 10:53 -
Ubuntu - Have you upgraded from 7.10 Gutsy to 8.04 Hardy?
By freebird73717 in forum LinuxReplies: 13Last Post: 18th Sep 2008, 01:11 -
Dual Boot Ubuntu Err 21 on PC with XPPro on RAID0 Drive and Ubuntu on eSATA
By videocheez in forum LinuxReplies: 32Last Post: 11th Jun 2007, 00:51
