INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Login:   Username:  Password:   Log me on automatically
Register I forgot my password I forgot my username Resend the activation key
searching for DVD Recorder cctv 24/7
Forum Index -> Hardware -> DVD Recorders Printer-friendly version
Reply to topic
Author Message
madsharpei
Member
Post Posted: Aug 22, 2007 10:05 Posts View users profile Send private message Reply with quote
Hi,
Is there a dvd recorder(no hdd) unit that has spare drive replacement parts available.I want to record 24/7 365 days for cctv use so when the drive fails the parts can easily changed.
trhouse
Member
Post Posted: Aug 22, 2007 12:50 Posts View users profile Send private message Reply with quote
If you look at eBay prices for non-hdd dvd recorders in general, the prices are about $80. You might be better off replacing rather than trying to repair at that low a price.
I have an invalid friend who had a burglary problem, so I helped him set up a cctv system with a dvd recorder just like you are suggesting ( without a hdd ) at first, then we tried a hdd recorder, then a dedicated surveillance hdd dvr. The non-hdd dvd recorder was a Panasonic DMR-ES10. It had the advantage of recording to dvd-ram which allowed recording and reviewing at the same time but the dvd-ram still needed to be replaced every so many hours.
The dedicated surveillance dvr is a much better solution for the following reasons
1) it can capture multiple channels at full D1 resolution with sound
2) it has a grid system for motion sensing ( not in the camera ) that activates recording of each channel only when the active grids see motion so you do not record lots of "nothing happening" time.
3) it can offload video to a usb drive in avi format for archiving.
4) in many units the hdd can be removed just by unplugging from the front panel for upgrading to a larger drive.
5) many are triplex in that you can monitor, record, playback or view via Ethernet simultaneously.
Reply to topic All times are GMT - 6 Hours
Forum Index -> Hardware -> DVD Recorders Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
