INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Search all forums or this forum: Advanced search
ipconfig /all
Forum Index -> Other -> Computer Printer-friendly version
Reply to topic
Author Message
willwoll100
Member
Post Posted: Oct 22, 2003 17:17 Posts View users profile Send private message Reply with quote
Can somebody tell me why when I type in ipconfig /all only a black window flashes up and not the window that should???
Also could someone tell me if your default gateway should be the same as
your IP address???
Will
stiltman
Hi Ladies
Post Posted: Oct 22, 2003 17:34 Posts Comp View users profile Send private message Reply with quote
Ipconfig has to be run from a cmd window unlike winipcfg. If run from the run command, it will just close after completing the command
start----run----type cmd, press enter---type ipconfig /all
your IP address???
Will
gateway will be different from your IP address unless you are a router...Then that's a whole different story
192.168.1.100 IP Address
255.255.255.0 Subnet
192.168.1.1-99 and 101-254 can be gateway
_________________
The ConvoPit
The Pub.......... lost their liquor license
willwoll100
Member
Post Posted: Oct 22, 2003 17:42 Posts View users profile Send private message Reply with quote
Thanks a lot for that bud
Will
g_shocker182
Post Posted: Oct 22, 2003 18:06 Posts Comp View users profile Send private message Reply with quote
I made a program to tell you yoru IP here:
www.angelfire.com/va3/ericswebspace/progs.html
hootie29
Member
Post Posted: Oct 25, 2003 20:29 Posts Comp View users profile Send private message Reply with quote
Microsoft has a little utility that will give you all that info plus has release/renew buttons at the bottom. Here is the link
http://www.microsoft.com/windows2000/techinfo/reskit/tools/existi ... pcfg-o.asp
Reply to topic All times are GMT - 6 Hours
Forum Index -> Other -> Computer Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
About   Advertise   Forum Archive   RSS Feeds   Statistics
