INDEX  F.A.Q.  SEARCH  LATEST POSTS     Rules  Register  Profile  Private messages  Login
Login:   Username:  Password:   Log me on automatically
Register I forgot my password I forgot my username Resend the activation key
Authoring DVD with Muxed MPEG-2 Track
Forum Index -> Video -> Mac Printer-friendly version
Reply to topic
Author Message
kamikaze
Member
Post Posted: Jul 12, 2003 12:43 Posts Comp View users profile Send private message Reply with quote
Hey!
I encoded a movie using FFMPEGX and it created a MUXed MPEG-2 file. Only problem is, when i go to import it into DVDSP it gives me an "unknown file" error. Won't let me import it, even though it plays back in QT just fine.
Anything I can do to solve this? I'd just change the type/creator codes but I don't see any reason to; the file shows up as a QT file.
I just want to burn this file to DVD with a few markers. That's it. If there is an easier way than DVDSP, i'd be willing to take that route.
Anyone?
TIA
bilestyle
Closet Monkey
Post Posted: Jul 12, 2003 14:57 Posts Comp View users profile Send private message Reply with quote
dude you gotta demux the file.. dvd studio pro doesnt accept muxed tracks.. use bbdmux or mpgtx to seperate the audio and video.. then you can import into dvd studio pro....also dragging files into the assets window in dvd sp is much more forgiving then importing through the menus.
_________________
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
kamikaze
Member
Post Posted: Jul 13, 2003 12:08 Posts Comp View users profile Send private message Reply with quote
Ok, so now I'm encoding the file without Muxing it. I had to re-encode because the first time, I didnt encode the video with DVD resolution specs. ( ie, did something like 320X240 instead of whatever the DVD standard is )
Only thing i'm worried about: This movie is encoded at 25 FPS. I wanted to keep that so that I wouldnt have to do any re-syncing...don't want to have to worry about that. However, I wanted to author a NTSC disc, so I selected the NTSC DVD resolution. I'm wondering though, if I go to create an NTSC DVD with my 25 fps movie file ( which is NOT the specified frame rate for NTSC ), will DVDSP not let me do that?
It'd seem silly, because the original film is 25 fps...which means if DVDSP wont take that as NTSC, I can only make a PAL DVD, or I have to completely resync the audio.
TIA!
bilestyle
Closet Monkey
Post Posted: Jul 13, 2003 12:54 Posts Comp View users profile Send private message Reply with quote
lol.. No you DONT have to re-encode it.. if you already encoded it just demultiplex the files, i think you are misunderstanding what im trying to tell you, also if you the video is 25 fps and you have an NTSC setup after burning it will not work properly, you need to change teh size and the frame rate to be NTSC compliant... no you dont need to worry about re-syncing.
_________________
kamikaze
Member
Post Posted: Jul 13, 2003 13:29 Posts Comp View users profile Send private message Reply with quote
So..you're saying if I've got an MPEG-4, and I go to encode it to MPEG-2, and I change the frame rate, that the encoder will automatically adjust the length of the audio track so that it matches the video track, hence, is in sync?
That's a helluva lot easier.
Also, is 576 X 252 a PAL standard? I'm wondering if it might be easier for me to just make a PAL DVD, but would it play on a north american TV and DVD player? I know they're just resolution and frame rate specs, but I could see there being an incompatibility.
TIA
bilestyle
Closet Monkey
Post Posted: Jul 13, 2003 14:03 Posts Comp View users profile Send private message Reply with quote
if you use apples mpeg-2 encoder and encode in NTSC format it will make all the necessary adjustments to the video to make it NTSC compliant.. if you author a PAL dvd and try to play it on your NTSC player it will NOT work properly.. it will be in black and white and will constanlty be flipping up and down ... totally unwatchable. the ONLY time you can play PAL video on a NTSC dvd player is with VCD/SVCD/CVD/KVD etc.. but not PAL DVDs.
_________________
El Scimitar
Member
Post Posted: Jul 15, 2003 21:49 Posts Comp View users profile Send private message Reply with quote
However, you can get players that play PAL. I was using the trick to change SVCDs to DVD and all that, and the result would be a PAL DVD (dimensions are the same as the SVCD though, so it is not a true dvd format). Anyway, my panosonic wouldn't play it of course, so I got a $50 Apex from Walmart (1110W or something like that), and it plays pal dvds. I know some other people that have Apex that will do the same. For being an inexpensive player it sure does a lot. So if you are just having home use for your dvds get an apex and same some hassle. But if you want to share with friends/family, and fun transcoding and all that.
bilestyle
Closet Monkey
Post Posted: Jul 15, 2003 22:36 Posts Comp View users profile Send private message Reply with quote
i do NOT EVER suggest buying an apex player.. they are cheap for a reason.. they are poorly built and they suck.. i had three apex players (all from different stores) before my current dvd player and they ALL sucked worse than ANYTHING i've ever had..(i would say including a PC if i ever was stupid enough to buy a PC)- even if its 50$ i would say its a waste
_________________
galactica
Macoderating
Post Posted: Jul 16, 2003 08:22 Posts Comp View users profile Send private message Reply with quote
Really? Ive had a Apex 1100W which worked GREAT! only got rid of it because i was pissed I had to get up and put the 2nd disk in when watching SVCD's
now i have the APEX 5131, and cant say anything against it! True, its not my only dvd player, but it does just what i want it to without a single problem
_________________
My Mac Video Website
AntnyMD
Member
Post Posted: Jul 16, 2003 08:59 Posts Comp View users profile Send private message Reply with quote
This is not the case. If you want to use the NTSC setting in DVD Studio Pro but some (or all) of your content is PAL, just make a MENU and use an image that is NTSC spec. Furthermore, make this menu your startup item, and you're good to go.
I did this myself last weekend and it worked fine, so I'm not speaking in theory here.
bilestyle
Closet Monkey
Post Posted: Jul 16, 2003 17:00 Posts Comp View users profile Send private message Reply with quote
well i dont know im not going to waste any more dvds to find out whether or not PAL material will work.. and if you have an NTSC setup and need to re-encodes the video to be DVD compliant anyways... why risk it? why not just make it NTSC and avoid any bizarre methods to get it to work.
_________________
AntnyMD
Member
Post Posted: Jul 17, 2003 06:41 Posts Comp View users profile Send private message Reply with quote
Re-encoding already compliant material is a waste of time. The DVD spec covers PAL as well as NTSC. If your NTSC television was manufactured anytime between the early 1990s and now, it will display PAL material just fine ... Just make sure you set your DVD player's setting from NTSC to AUTO, so that it automatically adjusts the PAL picture and framerate to your NTSC tv.
Reply to topic All times are GMT - 6 Hours
Forum Index -> Video -> Mac Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Jump to:
Display:
DVDFab DVD to DVD and Blu-ray to Blu-ray offers a 20% discount until Nov 22, 2009. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
