| Author |
Message |
mufca Member
Hi can anybody help????
When burning a Vcd Nero you are given a folder containing CDI,EXT etc
these folders contain information to tell the machine to read Vcd.
When I try to burn a Dvd the folders are empty.
Can anyone tell me what should be in the folders and where I can find it.
resnullius old skool member
you should look in the author section of the site.
hope that helps
_________________ #videohelp on dalnet!
EnemyWithin Member
In NERO, use the DVD (UDF/ISO) template (last one in the wizard). Then you will need to create 2 folders: AUDIO_TS and VIDEO_TS (caps are important). All of your files (.ifo's, .vob's, .bup's) should be placed in the VIDEO_TS folder, and NOT the root.
Dead Meat Member
When the template section opens in Nero, look up in the top left corner of the pop-up. There should be a drop down menu with CD showing. drop down the menu and change it to DVD. This will show you the DVD templates. Choose DVD Movie and put all your files in the VIDEO_TS directory. Burn away.
mufca Member
CHEERS Guys
I'll keep trying but any other help will be appreciated.
THANKS AGAIN
