VideoHelp.com Forum
  1. Can the .DAT file in the Mpegav folder on a VCD simply be loaded into a media player, say Windows Media player and played sucessfully?
    I love the smell of Napalm in the morning!
    Yes. it can. It's just to right click on it, then "open with" and choose media player.
    Excuse My English
  3. Hmm thats what I thought, so the problem I'm having must be in the burning somehow...the converted mpg plays fine, but once its burned to a VCD it's all screwed up and the audio is even worse.
    I've tried it using both Nero directly on the Divx and also going with TMPG and VCD Easy, both seem to give the same results. In fact the TMPG and VCDEasy way may be a little worse..
    If you intend using the original VCD footage for something else, then you need to xtract some of the "extra-bits" (technical term there) first to be safe.
    Use something like ISOBUSTER (free - see Tools link on this site) to extract from the VCD before you start playing with it.
    The glass is neither half-full, nor half-empty.
    It is simply twice as big as it needs to be.
  5. Not really trying to get stuff back off a VCD as such..just trying to get the VCD working...its the burning process where it all turns to custard...
    It appears to burn perfectly...but when it plays it's unwatchable...would converting from NTSC to PAL have such a big effect?
    what kind of vcd is it you're making exactly? if its a backed up copy of a dvd then use dvddecrypter,dvd2avi,tmpgenc and finally use nero to burn. the finished vcd or dat file should play fine in mediaplayer using hamman's instructions
  1. Ripping DVD with sub to be played on media player.
    By hanugro in forum DVD Ripping
    Last Post: 12th Feb 2010, 06:10
  2. Video dat file played only like audio file
    By newbievideohelp in forum Software Playing
    Last Post: 14th Oct 2008, 19:31
  3. Replies: 6
    Last Post: 10th Oct 2008, 13:17
  4. Replies: 7
    Last Post: 11th Jul 2008, 04:20
  5. Replies: 10
    Last Post: 28th Aug 2007, 10:25
