VideoHelp.com Forum
Results 1 to 9 of 9
  1. Now whenever i author with this program i added a completely legit mpg2 file, and prepare it. I get a warning message says "an error occured while writing a file. The item was not found'
    what the heck is it tell me, whats the possible error, can anyone please help me
  2. I received that exact same error. What worked for me was simply rebooting my computer and then trying to burn again. It burned perfectly for me after that.
    Now see I had a question about that as well, When I have an mpg2 or mpg1, Architect still converts the file which takes it for fricken ever! Do you guys do something different to make it go a little faster?
    DA1 works fine for me. It does reencode MPEG1 files, but does not reencode MPEG2 files except for the audio. MPEG2 files were made in both Vegas Video 4.0b, or Pinnacle Studio 8.
    You might want to try downloading DA1b from the Sonic Foundry sight, and see if that helps.
    Ron
  5. Член BJ_M's Avatar
    DVD A version C is out now (a couple of minutes ago)
    I have used this program fr the first time, when i played back the completed disc, the sound was out of sync. What a pain, thought i had found a good dvd authorer.
  7. Член BJ_M's Avatar
    i have never heard of that problem with DVDA - though i dont use it ...
    it has not been reported either as a problem on the sony support group forums ...
    if you have such an issue, and believe DVDA to be the cause - i suggest you contact sony and they will help you ...
  8. its depressing. sony dropped the ball with DVDA. I love Vegas...excellent NLE. DVDA just is missing a step. it takes tmpegenc dvd author 1/9th of the time that it takes DVDA. for some reason it always re-encodes the audio.
  9. Член BJ_M's Avatar
    try DVDA 2 first off -- and it will not re-encode compliant ac3 audio .. though i think in dvda 1 you had to do something ...
  1. DVD architect question
    By ingeborgdot in forum Authoring (DVD)
    Last Post: 22nd Oct 2011, 21:13
  2. DVD Architect 5.0
    By Mr. Robinson in forum Authoring (DVD)
    Last Post: 4th Nov 2009, 10:59
  3. DVD architect
    By romanstopme in forum Newbie / General discussions
    Last Post: 7th Apr 2008, 00:57
  4. DVD Architect help
    By monks19 in forum Authoring (DVD)
    Last Post: 23rd Aug 2007, 06:46
  5. DVD architect
    By Abiyad in forum Editing
    Last Post: 19th May 2007, 08:02
