Heya,
I just got ffmpegX and installed every thing correctly or so i thought... when the terminal window pops up it tells me there are certain files missing from the resources file. When I open the resources file, they appear to be there. Hopefully someone can point me in the right direction. Also which is faster in authoring a DVD, Transcoder 1.1 or ffmpegX?
Thanx,
Mullet
paste all of the terminal text into here
you are most likely missing something, or misreading it
heres whats it says in my terminal when i try to make an svcd...
Last login: Sat Apr 12 15:26:14 on ttyp2
pbpaste | sh
Welcome to Darwin!
[scott-dominicks-computer:~] scottdominick% pbpaste | sh
Encoding started on Sat Apr 12 15:26:15 EDT 2003
sh: dvd5/ffmpegX.app//Contents/Resources/movtoy4m: No such file or directory
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
sh: dvd5/ffmpegX.app//Contents/Resources/a52dec: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/mp2enc: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/mplex: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/mpgtx: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/vcdxgen: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/vcdxbuild: No such file or directory
rm: /Volumes/FCP Media 2/Desktop/svcd.1.xml: No such file or directory
rm: /Volumes/FCP Media 2/Desktop/svcd-1_02_pregap.img: No such file or directory
rm: /Volumes/FCP Media 2/Desktop/svcd.2.xml: No such file or directory
rm: /Volumes/FCP Media 2/Desktop/svcd-2_02_pregap.img: No such file or directory
rm: /Volumes/FCP Media 2/Desktop/svcd.3.xml: No such file or directory
rm: /Volumes/FCP Media 2/Desktop/svcd-3_02_pregap.img: No such file or directory
Encoding completed on Sat Apr 12 15:26:15 EDT 2003
thanx,
Mullet
you didnt run the other part of the installer
note there are two parts
one will install the necessary files, the other the app itself
likewise, you have to locate mplayer, mencoder and mpeg2enc files before the program will work all the way
Changelog.rtf
Credits.rtf
ffmpegX
Subtitles windows-1250.pkg
Subtitles iso-8859-7.pkg
ffmpegX engines installer
Subtitles iso-8859-1.pkg
Subtitles iso-8859-2.pkg
this is what you should have in the installer.
drag all of these to your harddrive, then run teh ffmpegx engines installer. You will need to located the items mentioned. If you dont have them let me know and ill host them for you to download, or you can get them from sourceforge
- galactica
Ok I did all the installations like you said and i still get the same results... this time i was trying to author a DVD... no dice...
Last login: Sun Apr 13 12:56:18 on ttyp1
pbpaste | sh
Welcome to Darwin!
Encoding started on Sun Apr 13 12:56:18 EDT 2003
sh: dvd5/ffmpegX.app//Contents/Resources/ffmpeg: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/yuvscaler: No such file or directory
mkdir: /Volumes/Shock and Awe/DVD.DVD: File exists
mkdir: /Volumes/Shock and Awe/DVD.DVD/VIDEO_TS: File exists
mkdir: /Volumes/Shock and Awe/DVD.DVD/AUDIO_TS: File exists
sh: dvd5/ffmpegX.app//Contents/Resources/ifogen: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/tocgen: No such file or directory
sh: ./ifogen: No such file or directory
sh: ./tocgen: No such file or directory
rm: /Volumes/Shock and Awe/DVD.DVD/VIDEO_TS/ifogen: No such file or directory
rm: /Volumes/Shock and Awe/DVD.DVD/VIDEO_TS/tocgen: No such file or directory
sh: dvd5/ffmpegX.app//Contents/Resources/mkisofs: No such file or directory
Encoding completed on Sun Apr 13 12:56:18 EDT 2003
I don't know what the problem is here... maybe i should try to get rid of everything and reinstall... I have dev tools... so that shouldn't be the problem... I dunno what to do
thnx,
Mullet
Move the ffmpegX application in the Application folder of your main hard disk. Don't use spaces or special characters in disk names and folder names.
.avi files that won't work correctly!
By RolloSwe in forum MacReplies: 10Last Post: 24th Feb 2011, 10:45 -
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 16:41 -
does ffmpegx work with MTS (AVCHD) files
By jps61 in forum ffmpegX general discussionReplies: 2Last Post: 9th Apr 2010, 12:13 -
Movie files created in ffmpegX won't open in QT Pro
By waterdog in forum DVD RippingReplies: 1Last Post: 7th Nov 2007, 17:35 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 08:37
