VideoHelp.com Forum
Results 1 to 9 of 9
  1. Tools: DVD Decrypter & ImgTool
    First thing you need to do is to create an iso.
    1. Launch ImgTool, and Locate the folder that your VIDEO_TS is in.
    2. Then select target folder and file name.
    3. Your volume name, should be the name of the dvd.
    4. Click image.
    Then you need to burn it
    1. Launch DVD Decrypter and change Mode to iso Write W
    2. Select iso.
    3. Write.
    by easy
  2. While imgTool may be a good program (this is the first I have heard of it), were you aware that DVD Decrypter ALSO writes image files (and a lot more). So if you have (and need) DVD Decrypter to burn the image to DVD, why bother with a second program to create the image?
  3. Banned
    he is using DVD Decrypter to write the image!
    IMG TOOL is used to create the image if all you have is a VIDEO_TS directory on your hard drive
    many programs produce only files and then you put them in a VIDEO_TS directory...with IMG TOOL you can create an image file that can be loaded into a virtual drive and tested to see if it works..
    then DVD Decrypter can burn it.
  4. Member housepig's Avatar
    Richkut -
    I think the confusion here is he's not ripping a dvd and then burning it, he's authoring content and burning it.
    So you could take the output of, say, NeoDVD and convert it to an image and burn it with freeware tools.
    Neat idea - especially if you got a bare OEM drive from somewhere without any burning software.
    - housepig
  5. Member Heywould3's Avatar
    Im just courious about this guide. Y not just use imgtool burn v 1.1.6 and burn the DVD with that? I loaded the program.. it asked me for the folder that i had my dvd riped to and it looked for the files and made sure all was fine.. it then burnt the dvd and plays fine in all 3 of my set top players.. im just wondering y this guide says to make an image then burn that? seems like an extra step? or does that solve some problems that some people might have?
    i do see that this question was asked sorta.. but its unclear as to the exact reason.
    is it that if you dont have a VIDEO_TS folder this will create that while making the img? the version of the program i used will do that also but burn to the burner too no img needed
  6. Member dphirschler's Avatar
    "with FREE tools" he said.
    Darryl
  7. Member Heywould3's Avatar
    Darryl
    Im sorry.. i thought imgtool burn was free.. i wasnt trying to debate his post.. i was truly just trying to understand his reasoning to make sure i wasnt going to run into any trouble.. for the record i dl that program from his link and didnt have to pay for it..
  8. Member dphirschler's Avatar
    It is free but requires Nero... which is not free.
    Darryl
  9. Member Heywould3's Avatar
    Ahhhh.. now i see said the blind man.. in looking deeper i see that it is attached to Nero.. i wasnt thinking since my burner came with nero express..
    Thanks for clearing that up for me..
  1. Replies: 1
    Last Post: 1st Mar 2012, 22:48
  2. Replies: 4
    Last Post: 31st May 2011, 01:44
  3. Replies: 2
    Last Post: 27th May 2011, 16:06
  4. Replies: 0
    Last Post: 22nd Aug 2010, 11:42
  5. Replies: 1
    Last Post: 1st Mar 2010, 16:03
