IS IT POSSIBLE TO ADD A PARENTAL CONTROL TO A SVCD WITH
AUTHORING PROGRAMS ?
I MEAN YOU HAVE TO ENTER A NUMBER OR ANOTHER CODE ON THE MENUE-SCREEN TO CONTINUE PLAYING THE DISC.
DOES ANYONE HAVE AN IDEA ?
Thread: PARENTAL CONTROL
there's some provision for 4 restriction categories, but those have to be implemented in the playing device... so this is 'client side security'
you can emulate some kind of code entry with selection menues; but then you could always override it by turning PBC off and play the sequence track directly;
you could put the controlled content into segment play items/... then this parts could be played only with PBC on... but this would only give you some security on standalones... you can always open the segment play items directly on a computer system...
if SVCD would support strong encryption, then you could implement something usefull... but well, as we have seen it didn't work for DVDs either (due to a major design flaws...)
so, there is no reliable content control system... and honestly, the only efficient parental control system is to physically lock up those SVCDs you don't want your children to watch...
thanks hvr
my children dont have access to my computer system...
I would like to try to protect a disc if playing on my standalone DVD.
Can you explain how to emulate a code entry and how to burn the svcd.
Why don't you just buy a box with a lock on it? Anything you come up with for software control is vulnerable.
Have you tried to block a VCD with your player ?. On my Sony I can block upto 50 VCD/DVD disks. If I add one more the first is lost. This is all done in the player not on the disk. Each VCD is diffrent and each disk can be givn a diffrent lock/unlock number.
This is slightly diffrent from the standard Parental control, but you may already have it without knowing
Philips models as well contain child lock facilities. What brand and model do you own?
I have a pioneer DVD that doesnt support SVCD and a no name that support all formats, both dont have parental control.
Therefore i have to try to lock on the disc.
I thought i can create a menue. To continue playing, player is waiting for input. Perhaps i can hide the numbers that someone has to press on the remote control for starting the chapters.
Does anyone have an idea ?
i lock my vcds in a cabinate.
i use a masterlock rated to whitstand a shot gun.
i keep the key with my carkeys.
Parental control for mac
By EmmaL in forum MacReplies: 5Last Post: 12th Aug 2010, 20:09 -
Parental Control
By HotDamn! in forum ComputerReplies: 13Last Post: 22nd Feb 2010, 20:50 -
WMP11 Parental Control
By jonghyunchung in forum Software PlayingReplies: 2Last Post: 4th Jun 2009, 13:55 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 21:05 -
help: parental control MARK tfe200
By moagutn in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2007, 01:45
