VideoHelp.com Forum
Thread: dolby surround?
  1. I want to get the best sound possible to my svcds. Is dolby surround the solution for me? How do you get dolby surround and does it take up more space on the disk?what tools are the best for it? I use smartripper, dvd2avi and TMPGEnc. please help me.
  2. Member adam's Avatar
    Yes dolby surround is the best possible sound you can get on either a vcd or svcd. I wont get into multichannel mpeg audio because although its superior, almost no one can actually use it. dolby surround sound is just a properly encoded stereo signal so its not any bigger than a regular stereo signal. The size is determined by your bitrate. You can use dvd2avi to downmix your audio to dolby surround. Just look in the audio tab. I believe that a higher quality method is to use graphedit and the intervideo decoder to do the downmix but the quality of either method is comparable.
    Of course in order to get dolby surround you need hardware that supports it or hardware that supports dolby pro logic, in which case you'll get pro logic of course.
  1. Replies: 2
    Last Post: 29th Apr 2011, 14:18
  2. Replies: 26
    Last Post: 6th Nov 2010, 17:38
  3. ac-3 pro plugin and dolby surround
    By ecc in forum Audio
    Last Post: 24th Dec 2009, 11:14
  4. Converting WAV file to Dolby Digital® 5.1 Surround
    By roma_turok in forum User guides
    Last Post: 16th Nov 2008, 22:32
  5. Dolby Digital Surround EX encoder
    By grasswhopper in forum Audio
    Last Post: 17th Aug 2007, 23:49
