Hey all,
So, low and behold I got the same problem as so many other people here and have learned a lot. My audio is out of sync. Surprise, surprise. Tried Goldwave/soundforge time stretch - no dice - made it worse -
What I want to try is
1) Setting the audio bitrate to a specific rate - but the original source file is in VBR. And I need to convert it to CBR. Does anyone know a user-friendly VBR to CBR audio bitrate converter?
2) I wish to correct any bad frames in the original source file that could be causing the desync - but VDub's scan video for errors options gets hung up on the first bad frame and doesn't continue - I get no summary of the all the bad frames and plus, I have no idea how to fix them or remove them. Is there a program that will do this? Scan the whole thing, summarize the errors and then give an option to fix or remove the bad frames?
This audio sync thing is pissin' me off.
Ice
Results 1 to 12 of 12
answer for 1:
Save the wav out by virtualdub, then load the wav, save the avi with a cbr mp3 ( video direct stream)Anyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
Could you be more specific please? I have already extracted the uncompressed wav from the original source file with Virtual Dub. Now I need to load that wav back into VDub?? I can only load a video file...not just a wav..if you could just elaborate that would be appreciated. Thanks
-Ice
under audio there is an option: wav audio. if you click it you can import an external audio for the avi loaded in vdub. Now if you save the avi ( save as avi) you'll have an avi ( audio video inter.....) wioth a wav sound .
Furthermore if you adjust the compression of the audio to cbr mp3 and then save, then you'll have a decent filesize as wellAnyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
Aaahhh I see! said the blind man to the deaf dog...
Thanks, I'll give that a go...according to your experience would that be sufficient to correct any audio desync caused by differences in bitrates?
I cant really imagine audio video desynchronization caused by different bitrates.. bitrates only affect the quality. What you are talkin about is vbr contra cbr. Older vdubs promt this at the beginning " improper vbr..... it will produce 79978 ms of skew...."
That is solved by this method . afterall vdub suggests to do this :arrow:Anyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
When proceeding with the above instructions you provided, what do the settings have to be under the video drop down menu in Vdub..full processing? direct stream copy? What settings do I use for the video since I am creating another AVI...
The VBR and the CBR is what I meant....so, by doing the method you suggested, that will clear up the audio desync problems?
Thanks for your insight, I appreciate it.
After loading in the wav audio, set video to direct stream copy, set audio to full processing mode and select an audio compression type.Originally Posted by MaximumIce
Which compression type should I use for the audio? And can I set the specific audio CBR?
Thanks again.
-Andrew
Why do you ask everything twice???? aaargh
video: direct stream
audio: full process, compression mp3 ( fraunhofer) cbr, resample to 41. khz precision 8 bit, stereo
that's it. arrrrgh, Read before you ask!!!Anyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
Hey
SOrry dude, Just that I've been trying to figure this out for awhile my head is swimming with so much stuff, it's hard for me to keep stuff straight. Thanks for the info!
Ice
Just one more thing,
Once I have saved an avi with CBR audio as per above instructions. How do I resample to 41 Khz with 8-bit stereo?
-Ice
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum CapturingReplies: 1Last Post: 16th Nov 2009, 00:11 -
Fixing bad PAL->NTSC conversion
By Goldmonkey2828 in forum Video ConversionReplies: 1Last Post: 30th Aug 2007, 19:40
