How do i convert an m2v file to a mpg or vcd format?
Thread: M2V, m1v 2 mpg/vcd
rgrah
M2V and MPV are video ONLY mpeg formats. Normally there should also be a MP2 or MPA audio ONLY mpeg file to go with it. You can then mux the MPV + MPA -> MPG w/ bbMPEG or TMPGenc (look under File | MPEG tools).
If you don't need, have, want audio then you can just re-name it to *.mpg (in theory).
i tried to rename the files and they worked BUT tmpgenc gives an error every time i open the file to convert it to a vcd to be able to play on my dreamcast
rgrah
.m2v + .ac3 + .sub/.sub to .mpg
By stevie99 in forum Video ConversionReplies: 2Last Post: 9th Apr 2012, 03:01 -
RMVB - AVS - M2V/MPG Audio Unsyncs
By koberulz in forum Video ConversionReplies: 7Last Post: 13th Aug 2011, 16:38 -
Used to stream .m1v, but now .m2v and..
By KameronK in forum Video StreamingReplies: 3Last Post: 6th Apr 2008, 11:48 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Authoring program? (m2v's/ac3's/mpg'sVOB's)
By RobAdam in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 06:53
Statistics
Newest guides
Latest tool updates
New media comments
