Hi, I'm trying to back up two dvd-video discs (both are single layer with only about 2GB of data) onto one dvd-r. I've ripped to my hard drive with dvd decryptor. Can someone direct me to a guide for putting these two movies onto just one dvd-r? A simple menu which just presents the two movie titles would do. Already installed tools:
dvd decryptor
dvd2one
copy2dvd
Thanks!
I don't know how to do it with the tools your using however if I was doing the same thing I would just import the VOB files into NeoDVD Plus then make a menu with chapters if I wanted them and press the "make DVD" button.
ok this is what u will need to do, extract all the movie files from disk. Leaving out the extras etc, so use ifomode in dvddycrpter.
This might be an option, put all the vob files into one folder and rename the files to carry on from the last one,
eg
First movie
VTS_01_01
VTS_01_02
Second Movie
VTS_01_01
VTS_01_02
what u will need to do is rename movie 2 to
VTS_01_03
VTS_01_04
to carry on with the vob sequence so in the end u will have
VTS_01_01
VTS_01_02
VTS_01_03
VTS_01_04
then use vob edit from doom9.org, demux the audio and movie from the vobs, and then u will have 1 m2v file and one AC3 file, with both movies and both sound tracks, all u have to do then is author it. u will have to make ur own chapters for the second film.
need more info ask.http://dvd.coldpie.com - where you can download versions of DVD2DVDR.
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Copy DVDs on my DVD Recorder?
By manda13 in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2010, 09:46 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 01:20 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
i have no idea how to copy my dvds to a blank dvd
By kmnyc7 in forum MacReplies: 7Last Post: 4th Oct 2007, 08:34
Statistics
Newest guides
Latest tool updates
New media comments
