VideoHelp.com Forum
  1. Hi,
    I just purchased ritek dvd+r 4.7gb without logos.
    http://www.blank-cd-cdr.com/dvdr-med...--r-4-7gb.html
    I noticed that if I burned over 4.3 gb I would always get an error( tried it 3 times)
    I was using Nero 5.5.9 and I have a sony dru120-a.
    Nero would give a scsi writing errror when the dvd was 97% finsihed.
    The dvd would play, but at the end would stall.
    After failing 3 times, I tried using a Verbatim dvd I bought from Best Buy and I had no problem burning.
    Has anybody had luck with these dvds?
    Thanks,
    Arthur
    I just finished a 25-pack of Ritek DVD+R, and I'm about to buy another. I had zero problems, and the discs seem to have very good compatibility; I haven't found a player yet that's rejected them.
    I'm using an HP 200i and Nero 5.5.9, all discs burned to full capacity.
  3. I have used over 150 of these with my HP 200i and maybe had 1 or 2 fail but I get them to burn to 4.4 gigs with Recordnow DX and 4.38gigs with nero
  4. Hi,
    Did any of you guys have to upgrade your firmware in order to get your dvd writer to work with these dvds?
    The help desk guys said I should upgrade my firmware.
    Dont feel like doing this if I dont have to. I mean it works fine with other dvds.
    thanks,
    arthur
  5. Member spidey's Avatar
    Yes, I'd definately make sure you're using the newest firmware to comply to the discs
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  1. Experience of lifetime – cut out parts of DVD to make a smaller version
    By technogeek in forum Newbie / General discussions
    Last Post: 10th Sep 2011, 00:28
  2. vhs to dvd experience
    By victoriabears in forum Capturing
    Last Post: 20th Sep 2010, 19:10
  3. Replies: 4
    Last Post: 31st Mar 2010, 22:32
  4. My VHS to DVD experience
    By Oob in forum Capturing
    Last Post: 26th Oct 2009, 21:10
  5. Any experience with Samsung HR 773 DVD recorder?
    By szalaikornel in forum DVD & Blu-ray Recorders
    Last Post: 14th Jan 2009, 06:09
