VideoHelp.com Forum
  1. ok i followed exactly the guide on how to add permament subtitles using virtual dub and tmpge, but when i get to the tmpge part, it would couldnt open the file. i also noticed that the file that i save in virtual dub was just a file, not a .vdr file. so i renamed it to *.vdr and it still didnt work. can someone please help me?
  2. I don't you try to add subtitles with another aplication like the submux that is included in the vobsub package(http://vobsub.edensrising.com/).
    Which guide are you using? When you go to frameserve from VirtualDub you need to type in the full file name (whatever.vdr) and leave the framesever running, start TMPGEnc and load whatever.vdr (you might have to change the "Files of Type" drop down to "All files" in order to see it) then setup TMPGEnc as you normally would. You can't close the frameserver or rename or move the file once you've started.
  4. for me is everything working fine EXECPt the part when you have to open the file (watever.vdr) but when all is done, with frame server open and running, mpegenc says: ILLIGAL STREAM FORMAT! what shoud i do? i think i've followed the right steps...
  1. Replies: 0
    Last Post: 27th Dec 2010, 15:53
  2. adding new subtitles over existing ones
    By fishdog in forum Authoring (DVD)
    Last Post: 22nd Apr 2010, 02:22
  3. adding subtitles
    By dabud in forum Authoring (DVD)
    Last Post: 20th Oct 2009, 22:27
  4. Adding subtitles
    By tommcd64 in forum Authoring (DVD)
    Last Post: 28th Aug 2009, 00:39
  5. Adding subtitles
    By Avril in forum Mac
    Last Post: 18th Jan 2009, 13:43
