while capturing or watching video with ati all in wonder the sound get's distorted when right mouse clicking.Also after capturing the sound is not that good.I had intergrated sound card so i purchased the audigy sound card to try to resolve this problem but it didn't work.Any help would be appreciated.thanx rick
Results 1 to 10 of 10
if your motherboard is a via then try this....
http://www.georgebreese.com/net/software[/url]How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149
how do i tell what my motherboard is,also i tied this link with no success,i went to the website but i'm not sure what to look for?
AI have to ask are you inputing the audio to the Line input and not the mic input? Inputing the mic input could overdrive the audio and cause distortion or audio clipping.
I've got it set into the line in
Well then check in the creative control panel and make sure no post filtering or reverb is enabled then set the volume control down and see if that helps. That's all I can come up with short of you having DX components that are corupt.
How about the motherboard tip,is that worth looking into,i don't know how to see what motherboard i have.I have a brand new hp 3ghz computer.by the way thanx for taking the time to work with me on my problems,i'm getting vey frustrated
If you have a HP computer then my guess they made the motherboard. To check if the board has the VIA chipset you could look in system device manager under system (I think) for any VIA drivers installed.
I agree with Bob W if it's a HP then chances are it's a HP manufactured mobo....
I myself have a beef with HP so I won't go baggin but I will say this everythin for a HP is generic....the sound card the video card blah blah blah...so you can't exactly use the lastest nvida drivers which are mad but can stuff your cap setting (but if you know what your doing it won't effect it) you have to use HP drivers .....but my experience is with older HP's maybe they're better these days
but here is something in perspective
My friend spent $2500 Australian on a HP 2.0 Ghz 256 DDR ram 40gig HD it looks sexy those metalic keyboard blue slim lines etc ...but it crashes it's slow I have in the last year reintalled xp twice ...and he doesn't even doing thing with it except surf the net and use photoshop
My beast a celeron 1.2 ghz 640 mb ram leadtek 250ddr graphiocs card soundblaster etc cost me $900 australian and it is solid as a rock never crashed I keep this thing runnin day and night encoding uni work gaming etc the only prob I had was it's a VIA chipset but used the patch by george breeze and perfomance and stabilty is second to none
You can find out your mobo by going to control panel click on your motherboard and som info should be there...
You want the patch that suits that ...but he has (i think 2 different ones)How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
Capturing Hi8 video using Sony TRV320E D8 (PAL) camcorder distorted audio
By lchiu7 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 18th Sep 2011, 16:39 -
Audio Sound Distorted
By Teac23 in forum Software PlayingReplies: 0Last Post: 1st Aug 2010, 07:40 -
WMP 11 can play video file and but produce distorted sound at 48Khz
By hulinning in forum Software PlayingReplies: 1Last Post: 13th Nov 2009, 21:02 -
Distorted sound
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2007, 18:40 -
distorted sound
By phillyrider in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2007, 06:25
