I'm trying the header trick from the guides to play in my Panasonic CP67 dvd player. I used Virtual Dub to save the audio as a wav, converted the divx to an mpeg2 with TMPGEnc, did the header trick, then used TMPGEnc to cut it to fit on 2 discs. When I did the header trick, I got an error about buffer overflow & that playback might be affected (or something to that effect). Sure enough, the movie stutters. It plays for 1 sec., freezes for 1 sec. etc. Does anyone know if this is a bad divx (I know, I should have scanned for bad frames), was the conversion to an mpeg2 or the header trick corrupted, is my computer too slow (Celeron 433a w/ 256mb sdram) or is it a compatibility problem with my dvd player?
Thanks,
Chris
Results 1 to 1 of 1
Watch MPEG2 SD Card Movies on Panasonic TV
By LOWTECH in forum Video ConversionReplies: 2Last Post: 10th Apr 2011, 16:08 -
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 18:23 -
Panasonic DMP-BD45 & 65 & DivxHD?
By inoueto in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Aug 2010, 17:46 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 05:55
