If you select SVCD stills you cannot deselect the TV correction.
But with VCD it works!
Please correct that issue. Then we can input 704x576 stills for SVCD or picture slide shows.
The qualtiy of pictures sucks when you need more than one resizing step.
(photo editor + Vcdeasy)
The resizer of VCDEasy doesn't make good sharpness. So I use this function with IrfanView or another editing program. The output is a folder with aspect ratio corrected 704x576 stills, ready for mpeg encoding.
Same thing with captured stills (720x576). The pixel aspect ratio (PAR) is ok, and we only need to crop to 704x576.
BUG
MPEG2 stills (SVCD) are generated with too much bitrate, resulting size is about 200 kbyte. Most DVD players can't show it.
The max. bitrate is 9800 kbit/s, then the size of a 704x576 mpeg2 still should be about 56 kbyte. VCDEasy cannot generate that size.
Results 1 to 1 of 1
Thread: Problem on SVCD MPEG stills tab
How to Author an SVCD with menus and stills Under GNU/Linux
By khey in forum User guidesReplies: 1Last Post: 24th May 2011, 23:35 -
Where is the MPEG-2 selection in the summary tab To Target Setting
By RL in forum ffmpegX general discussionReplies: 3Last Post: 31st Jan 2011, 15:42 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 16:28 -
Problem with stills (badly rendered) in Premiere 6.5
By Dennuz666 in forum EditingReplies: 4Last Post: 26th Jul 2007, 08:01
