VideoHelp.com Forum
    hi
    i was wondering if anyone has dabbled in any blue screen work. i wouldnt mind having a go. can anyone share some advice or recomend a good site. i only have an analogue video camera. does this make a difference?
    Peter H
  2. Member Conquest10's Avatar
    no the camera won't really matter (as long as it takes clear video). just make sure the set is well lit. also make sure the person is not wearing any blue/green (depending on what color you use). green is generally easier but tends to bleed more. so you have to light it better and make sure the subject isn't too close to the screen. blue is used more for action scenes.
    His name was MackemX
  3. No Longer Mod tgpo's Avatar
    I've gone some with After Effects. The best advice is lights, lights, lights and lights. If you don't properly lights the blue/green screen then you'll end up having to re-tape it or just mask it in After Effects. But make sure you don't light to the point where it is washed out white. It needs to just keep the backdrop a constant color.
  4. Member Conquest10's Avatar
    i use after effects, too. its the easiest thing i've used for blue screen. just select the color and BAM its gone.
  5. No Longer Mod tgpo's Avatar
    Exactly. It's almost too easy. But again, while you can change the color tolorance, constant color is critical.
  6. After Effects is really good for Keying though recently I've been trying out Avid Xpress DV 3.5 and found it to be even better, as you'd hope and expect, with many more features.
    Here's two PDFs on Lighting and using keying in AFX:
    Lighting
    Keying in AFX
    i have ulead video studio 6, has anyone tried it with this program? thanks for all the help anyway, ill do some more research.
    Peter H
  1. HELP! Black screen/Blue Screen problem
    By will7370 in forum Computer
    Last Post: 1st Apr 2012, 09:30
  2. Again blue screen!!!
    By alintatoc in forum Computer
    Last Post: 10th Dec 2009, 14:16
  3. Blue screen?
    Last Post: 1st Nov 2009, 06:53
  4. what's a blue screen?
    By aruwin in forum Computer
    Last Post: 23rd Sep 2009, 08:56
  5. Blue Screen Of Death
    By Squid_uk in forum Computer
    Last Post: 31st Mar 2008, 14:35
