VideoHelp.com Forum
    I've been working on encoding this file to vxcd for more than a week with many attempts. My xvcd file plays fine on media player, although, on my dvd player the framerate is slow and the picture is "all over the place". There is pixilation and the bottom half of the frame is on the top half. UGH. I tried de-multiplexing (whatever that guide said) and I had the same problem. I'm also wondering is converting to a 16:9 widescreen mpeg would have caused this problem. THANK YOU. MERCI.
    Bravoxena
    30+ views and no answers? :'(
    Bravoxena
  3. Member Conquest10's Avatar
    gonna need some details. can your dvd player play xvcds? by 16:9, do you mean you encoded the file as a 16:9?
    His name was MackemX
    my dvd player has played xvcds before, and i trust its compatibility. and yes, i encoded the file AS A 16:9.
    Bravoxena
  1. Why does my plasma TV have odd shading?
    By akocnc in forum DVB / HDTV
    Last Post: 18th Sep 2009, 12:16
  2. Odd slowness
    By Lucifers_Ghost in forum Computer
    Last Post: 22nd Jan 2009, 18:08
  3. Changing FPS for odd ones is this possible
    By SUPERIOR in forum Audio
    Last Post: 29th Dec 2008, 02:23
  4. Odd Windows Error
    By Poppa_Meth in forum Computer
    Last Post: 6th Dec 2008, 12:18
  5. Space requred seems odd
    By jriker in forum Restoration
    Last Post: 2nd Feb 2008, 11:45
