I was trying to split an avi in two parts therefore I used VirtualDub and I tried it with AviSplitter as well.
I chose the beginning of an part and then the end.
Everything works fine. BUT:
The second part starts maybe two seconds earlier then what I set the beginning frame to! Any suggestions how I can fix this problem.
So that the one part ends and the next part beginns at the same frame?
If you are cutting a Divx or Xvid clip, it may be jumping to the previous keyframe rather than the frame you would want.
Yes, a clip must start at a Key frame. You can cut the end of a clip anywhere you want, but the start of a clip must be set at a Key frame. Use the Key frame button in Vdub to find them. 8)
Frame accurate cutting of H.264 files
By Ahari in forum Newbie / General discussionsReplies: 17Last Post: 30th Apr 2012, 04:33 -
Frame accurate cutting on m2ts files?
By stryker412 in forum EditingReplies: 3Last Post: 29th Jan 2012, 04:20 -
AsfBin: cutting by frame & container
By videohalp in forum EditingReplies: 3Last Post: 2nd Sep 2010, 00:48 -
cutting MPEG frame by frame
By headless chicken in forum EditingReplies: 3Last Post: 9th Nov 2009, 19:45 -
Cutting AVI files by frame or keyframe?
By squegole in forum EditingReplies: 6Last Post: 1st Jun 2007, 12:25
Statistics
Newest guides
Latest tool updates
New media comments
