Hi folks,
I tryed Smart ripper for DVD to DIVX and it,s great, but, it split file if is over the setting you choose, so if I have 2 hrs DVD, it will split after 700Mb for another CD. Is any possibility to put all 2 hrs movie on just 1 CD, or at least 1:45 minutes and how to adjust output for it.
Can Smart ripper do that or I have to use another program.
Try AutoDub 1.75. Automatically fits your movie to one CD or two CDs. Easy to use program. Lets you manually change settings too.
www.dark-angel.does.it/
Before you use it though, you will need to convert your DVD to a *.d2v file with DVD2AVI 1.76.
If you go to the divx-digest.com forum there is a post talking of a program called dvx(something) it sounds pretty sweet, and it might do what you are asking for.
Blah, blah, blah
DVD/DivX Video Cataloguing software..
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 19:37 -
Fastest / Best software for dvd to divx?
By butt_crack in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2009, 01:35 -
Which is Best Resolution for 1CD DVD-Rips
By mani4frenz in forum DVD RippingReplies: 11Last Post: 28th May 2009, 08:53 -
Recommended software for DVD to DivX
By craigwojo in forum DVD RippingReplies: 6Last Post: 18th Feb 2008, 08:10 -
DivX on DVD Autorun Software
By Burgos in forum Software PlayingReplies: 0Last Post: 31st May 2007, 09:13
Statistics
Newest guides
Latest tool updates
New media comments
