Hello, is there a scart-adapter which allows me to take an S-VHS signal out of a SCART connector and take it to my tv-tuner s-vhs input ?
I've seen some scart adapters with S-VHS and 2 audio rca-connectors but they said they are inputs :S or am I being silly now.... (I guess I'm a typical newbie at capturing)
Thread: Scart ->S-VHS adapter ?
If your video source is a S-VHS VCR, you can use a passive SCART->S-Video converter.Otherwise you'll need an active one.
Using a passive converter will give you only a B&W picture, as standard VHS VCR cant produce the chrma signal.
But with some electronic equipment, it's possible to get the chroma and luminance siglas (S-Video signals) out of RGB.You can even get S-Vdeio out of composite, but IMHO that's not the point, because this is not better than the original signal.
Hmm...my vcr has a scart and a regular coaxial antenna connection...should I just settle for capturing from the coaxial..what other options do I have?
You shouldn't use the antenna connection.If your VCR doesn't have a RCA coax video out (quite unlikely), get a SCART->RCA (composite) converter.This should always work.But beware, there are 2 kinds of them:video-in and video-out.You need video out.
Okay, thanks for the advice.
I was just wondering about the use of s-vhs since according to a guide
I had it promised best quality after the scart connector (antenna being worst) I guess I can live with using composite. Cheers !
VHS-C transfer: adapter or camcorder?
By moxiecat in forum RestorationReplies: 31Last Post: 15th Jun 2011, 17:18 -
Scart to VGA VHS capture
By Juc1 in forum CapturingReplies: 6Last Post: 25th May 2010, 11:45 -
VHS to DVD - Looking for a decent USB Adapter
By foochuck in forum CapturingReplies: 0Last Post: 11th Jul 2009, 17:58 -
Is there a VCR that will play VHS-C tapes without an adapter?
By moxiecat in forum RestorationReplies: 22Last Post: 23rd May 2009, 16:20 -
Problem capturing from VHS recorder via SCART
By Freebird in forum CapturingReplies: 8Last Post: 29th Aug 2007, 13:18
