VideoHelp.com Forum
Results 1 to 16 of 16
    i want to convert a file from mpeg2 to mpeg1
    u know, same quality as the mpeg2, but in mpeg1 format
    is it possible to do this? any recommendation?
    thx in advace
  2. multiplex it with tmpgenc.....video header trick will make it a mpeg1 with mpeg2 quality
    Here's a link to the VCD Header Trick:
    http://www.vcdeasy.org/modules.php?n...es&id=VcdTrick
    Hope That Helps!!! :P
  4. I also use the vcd-header trick but the problem is when I convert the mpeg2 file to a mpeg1 file (video-cd) the file increases with more than 200MB
    Why is that and is there a way to prevent this?
    trenchy
    this is the error i got from tmpgenc after it finished multiplxing the file
    "Warning
    65912 s packets cause buffer underflow.
    The MPEG file might cause error when it played."
    and when i play the file w/ powerdvd and windows media player, there's no picture, only skippy sound
    i've tried it w/ different mpeg2 files but same error appears
    yes m8........that will happen when its played on a pc.....but 99% of dvd standalone players will play it normal.
    burn to cdr and try m8.
    really?
    so that file's suppose to be skippy and destructed when i play it on pc?
    but when i put the product file back to the multiplex tab
    it still appears as a mpeg2 file
    Originally Posted by trainspotter01
    really?
    Burn the file and it should play back OK on your DVD player without any skipping.
    i did, still skipping
    that's y i use the multiplex f'cn to check the file again, and it turns out it's still mpeg2 even tho i did the multiplex trick
  10. What vcd header do you use?
    I first tried the vcd non standard header which gave bad result
    Then i tried vcd header which gave good results
    trenchy
    XVCD, 352x240 (or try 352x480) with 2600 bitrate looks good to me. Another thing: anything on CD will NEVER look as good as DVD. Really good? Yes. Like DVD? No. SVCD is about as high as you get. If SVCD is not an option go for the next best, the XVCD I suggested. If it won't work. Keep asking. I don't mess with CD too much, I have DVD burners.
  12. hi there
    filempeg2.mpg (352x288/352x240) de-multiplex
    then multiplex again -first add files then adjust the header in the tab as VCD NON-Compliant and you will have the same size
    if using the standar VCD the file will be bigger
    remember that the frame size should be 352x288 or 352x240 otherwise
    the standalone DVD won´t play it
    2man
    read this guide again m8 and make sure either video cd or video cd (none standard) are selected.
    trenchy: i've tried everything, vcd non standard, vcd standard, both mpeg1 system, still not werking
    txpharoah: yeah i know it just cant be as good as DVD~
    but at least i want my file to play smoothly, and now it's not~~~
    2man: but i thought those (352x288/352x240) arent the frame size of mpeg2 file?
    KYUSS: i've read it like 10 times! and i'm pretty sure that i followed all the procedures~
    Also, the header trick doesn't work on all players either.
    If the motion is jerky, be sure to LOWER the motion quality (it does not mean low quality, I'd explain, but don't have time for that novel), and lower you GOPs to under 3 each. Even 1 each I/B/P if needed. That should fix motion.
  1. High Quality Encoding AVI -> MPEG2
    By vl0001 in forum Mac
    Last Post: 21st Jan 2012, 08:40
  2. avi -> mpeg1 in high quality
    By steve1401 in forum ffmpegX general discussion
    Last Post: 6th Nov 2009, 19:53
  3. lower low quality online tv how to high quality :( :x
    By gorry563 in forum Video Streaming
    Last Post: 22nd Feb 2009, 06:56
  4. Replies: 2
    Last Post: 9th Feb 2009, 18:33
  5. Replies: 9
    Last Post: 9th Jul 2007, 08:27
