Hello
Since I purchased a 1,7 ghz machine to replace my PII now my old ATI ISA TV-tuner is useless since the new motherboard has no ISA slots and I was wondering what TV_TUNER card would give the best quality in the price range of 0 to 100 euro (or USD)
My plan is to capture AVI from tv broadcasts and from VHS tapes and encode to DIVX and PAL SVCD/VCD.
Thread: Recommend a capture card ?
The Leadtek TV2000 XP Deluxe is a popular one. I am using one right now and it's a great value. You should be able to find it for about $55-60 US.
Xcapture from prolink uses the new conexant chip 10bit
http://www.prolink-usa.com/english/p...do-bt881p.html
It works great for me and is cheap
I would recommend a card based on the nwere conextan chip or a philips chip. Xcapture uses the latest conextant chip but the Leadtek use the older chip. I believe Leadtek will be realising a newr version of th card.
If you looking for just capture and no TV tuner then I would suggest the Xcapture.
i use the leadtek and it is great. $60 and that includes $120 worh of software i would go for it but then again that other 1 sounds nice, it is new, but leadteks setup is easy, and the thing works great.
"joe"
ko woh sitcwhde my kyeotps auornd
Thanks for the suggestions.
I definetely need a TV-Tuner since it's cheaper than buying
a new tv-set
My OS is WinMe
Can all tv-tuner cards capture ..let's say 640 x 480 ?
I can't find Leadtek or such in where I live...lots of
Hauppauge, Terratec, Hercules, Ati, Pinnacle, Canopus Magic and Lifeview.
They told me at my local shop to purchase a Hercules stereo-tuner...
go to www.newegg.com for the leadtek, it gets 640x480 and more. like i said $60, if you are going for a tv-tuner this is one of the best out there.
Recommend Capture card/stick pls
By jubbely2 in forum CapturingReplies: 5Last Post: 27th Oct 2010, 12:14 -
Can any one recommend a tv capture card?
By Stevet1972 in forum Video StreamingReplies: 2Last Post: 19th Nov 2009, 06:08 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum CapturingReplies: 12Last Post: 13th May 2008, 17:52 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum CapturingReplies: 7Last Post: 5th Feb 2008, 07:25 -
Recommend AGP 4x capture card for P4 2.4GHz computer please??
By w@ntonsoup in forum CapturingReplies: 16Last Post: 9th Oct 2007, 11:05
