VideoHelp.com Forum
  1. I’ve been creating some photo VCDs with Nero 5.5 and all works extremely well but I was wondering if I could add some music to the VCD instead of it just flicking from one photo to the next in silence?
    My system……
    1.2 Ghz Athlon
    256MB ram
    40 GB ultra DMA HD (35GB free)
    IEEE 1394
    Windows ME
    DVD 16x
    CD-RW 8x4x32
    Located in UK (Pal)
    Thanks in anticipation…great site BTW
    Dave
  2. Simple answer No, not with Nero you cant. You can with WinOncd 3.8,which I consider the best for Photoalbums.With regards to Nero your only option is to convert your stills to mpeg with something like Adobe Premiere, although its fairly time consuming.Hope this helps you out.
    Regardsatsym1
  3. Many thanks for that speedy reply. I’m going to check out the prog you suggested.
    Dave
  4. Try double clicking an mp3 file while you browse your pics,
    voila -> music
    couldn't resist..sorry
  5. Remember, cce is the fastest. If you want to get it done, in high quality, with effects, edited pics..repairs-whatever, add audio, then use premiere 5.5 with the cce 2.62 plugin. You just can't best the speed, abilities and quality.
    <font size=-1>[ This Message was edited by: legman on 2001-09-09 20:48:01 ]</font>
    i think if u had a 3 disk changer, you could put a photo vcd in one slot and then a mp3 or audio cd into anouther slot and play them both
  1. inserting photos within a music video
    By Olustee bus in forum Newbie / General discussions
    Last Post: 6th Sep 2011, 10:47
  2. Inserting photos in a music video with movie maker
    By Olustee bus in forum Computer
    Last Post: 5th Sep 2011, 11:30
  3. Replies: 2
    Last Post: 30th Mar 2010, 17:34
  4. Thinking of ditching AppleTV and using PS3 for movies/music/photos
    By bobogs in forum Media Center PC / MediaCenters
    Last Post: 14th Nov 2009, 22:21
  5. help! adding background music
    By Keier in forum Newbie / General discussions
    Last Post: 23rd Jun 2008, 14:30
