I have an mpeg-2 file downloaded from LikeTV that they encoded at 4000kbps. I'd like to lower the bitrate to max 2520 cuz that's the highest my standalone can handle, then burn it as an SVCD. But when I try to load it in Tmpgenc Plus 2.58 it reports: file format unsupported. I tried increasing directshow to as high as 6 without success. Then I read another message here that said installing the trial version of PowerDVD would add the neccessary plugin to Tmpgenc. But after installatimg Powerdvd (and a reboot), there were no new plugins in the listings and Tmpgenc still can't open the file. Any ideas what the problem might be?
Does PowerDVD or any other program run the video?
Hello.
Yes, it plays fine on PowerDVD, start to finish.
Interesting. I would try Virtual Dub's MPEG-2 mod from the Tools section, then try Video Studio 6's demo version.
Hello.
Are you using a trial version?
Use TmpEnc plus, here you can work with mpeg-2 files
I have the same problem sort of,I can only load the video(.mv1)but not the audio.I have the MPEG-2 plug-in installed and I get an error in Environmental Settings saying"the file cannot be loaded".
Can VBscript/Batch read MPEG file?
By Cazz in forum ProgrammingReplies: 11Last Post: 3rd Sep 2010, 07:50 -
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
DGMPGDec plugin for AVISynth doesn't read MPEG file's audio
By Mark001 in forum Video ConversionReplies: 11Last Post: 9th Jun 2007, 18:07
