VideoHelp.com Forum
    I used to be able to rip DVDs at 7x or more but now they wont rip any higher than 2x. Has anyone else had this problem?
    I have the Lite-On HD163 drive, well known for it's high ripping speeds.
    Cheers
    Check if DMA is enabled.
  3. Maybe a stupid question, but how do you verify that DMA is enabled in Win XP? I have the same problem w/ slow ripping.
    1-Right click on 'My Computer'
    2-Click on 'Manage'
    3-Click on 'Device Manager'
    4-Double click on 'IDE ATA/ATAPI controllers'
    5-Double click on 'Secondary IDE Channel'
    6-Click 'Advanced Settings'
    7-Check that the transfer mode for all your devices is set to 'DMA if available'
    8-Click 'OK' to finish
    9-Now reboot
    I have changed to DMA if available but windows will only use PIO mode. Is this something to do with my BIOS settings, even though my other drive works in DMA mode
  1. how to rip dvds?
    By adventurousman in forum DVD Ripping
    Last Post: 1st Apr 2012, 09:10
  2. Can not rip 2 dvds!!!!?
    By jamespoo in forum DVD Ripping
    Last Post: 9th Sep 2011, 00:54
  3. Hard-to-Rip DVDs
    By FullGrownNut in forum DVD Ripping
    Last Post: 8th Jul 2010, 07:57
  4. How to RIP Television DVDs?
    By thesensfan in forum DVD Ripping
    Last Post: 31st Oct 2009, 02:03
  5. Rip DVDs to PC
    By vlitim in forum DVD Ripping
    Last Post: 13th Mar 2009, 10:12
