I am wondering how DVDXCopy splits the disks, do you have to swap disks in the middle of the movie ?
I was trying to create a disk with the menu and movie on one and the menu and extras on the other using Instant Copy, however the disk won't play in my stand alone, it does however play in my PC... I know the disks work and so does the burning method as I have done it before with Stuart Little, however with Stuart Little I lowered the quality and put it on one DVD+R...
Is it possible to accomplish what I want to accomplish: Near perfect DVD quality with menu and movie on one disk and menu and extras on the other ?
TIA...
With DVX Copy yes you have to change the disc. When you reach the end of the first disc it will tell you to insert the second disc. It's no big deal to me. Also the program does not re-encode the movie so the copy is exactly the same quality as the orignal. Would be a great program is the price of media was $0.5 or less each.
Thanks for the reply, I may just go ahead and give it a shot with DVDXCopy and see how it goes...I'd prefer to do it the other way but I am not sure if that's possible...
DVDX Copy works great and is faster than Instant Copy overall plus again the quality is orignal. Myself I really don't care about the menus or extras so I mostly use DVD2one.Originally Posted by PM5K
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 12:40 -
Split bd 50 into 2 25gb disks
By fremat in forum Blu-ray RippingReplies: 1Last Post: 23rd Oct 2009, 09:04 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24
Statistics
Newest guides
Latest tool updates
New media comments
