I have the RV32 and access to an RV31
The RV32 says it can do SVCD, and does work with the VCD header trick.
The RV31 cant do SVCD but it will work with the VCD header trick.
I have tried just about every combination of to get SVCD to work,
Today I found one that worked perfectly
1. TMPGenc Mpeg tools
MUX the .m2v and .mp2 as MPEG2 PROGRAM stream instead of MPEG2 SCVD stream.
2. VCDEasy
Create SVCD 1.0 and add your .mpg, it will tell you that it will autopad the file on the fly.
Burn the CD
3. RV32
Put SVCD in player and enjoy
I don't think that this is a perfect solution
Because if I understand this right, the .mpg stream is padded
when it muxed, and then padded again by VCDEasy
which did increase the file size
So it is possible that a rip might not fit in certain cases
Next, I am going to see what I can do with bbmpeg
to mux a mpeg2 stream and/or mpeg2 scvd stream
hopefully that works, I'll post back what I find
Phibertron
Results 1 to 10 of 10
I was able to get BBMPEG to create a correctly muxed SVCD mpeg
made from a KVCD3 mpeg2 template
So now I don't have to worry about a huge file increase
caused by muxing an mpeg2 stream and then padding it to svcd
with vcdeasy
I'd like to attach a pic of the settings, but ...
So here are the settings I used that worked
Tested settings #1 - Worked
SVCD = Bulleted
VBR = Bulleted
Write Program EndCode Bulleted
Computed Birate = Use Max
TimeStamps = All Frames
Pulldown = Auto
Forced Mux Rate = 0
Pack Options Size = 2324
Pack Options Pack = 1
Buffer Sizes Video = 46
Buffer Sizes Audio1 = 4
Buffer Sizes Audio2 = 4
Startup Delays Pack = 0
Startup Delays Video = 180
Startup Delays Audio1 = 180
Startup Delays Audio2 = 180
Tested settings #2 - Worked
SVCD = Bulleted
VBR = Bulleted
Pulldown = Auto
Forced Mux Rate = 0
Startup Delays Pack = 400
Startup Delays Video = 344
Startup Delays Audio1 = 344
Startup Delays Audio2 = 344
I'll play around some more and post back what I find out
from my button pushing =)
Phibertron -
did some more thinking and experimenting
KVCD3 MPEG2 is used for most of my encodes,
and I remembered that one of the setttings in the TMPG templates
was that the VBV buffer in TMPG was set to 40 which is for VCD.
I have read that 40 is for VCD, 112 for SVCD, and 224 for DVD
That got me thinking about the Buffer Sizes Video setting in BBMPEG,
and that it is using 46 for VCD, 230 for SVCD, 46 for MPEG1 and 224 for MPEG2.
I am making a wild guess that these settings must be very closely related.
So I created a standard SVCD using TMPG included template with a VBV of 112
Then I muxed the m2v and mp2 with BBMPEG changeing Buffer Sizes Video setting to 46
and burned it with VCDEasy
Well what do you know, it worked perfectly, phew!
It looks like Panasonic's firmware cant handle a 112 buffer for SVCD
but can handle a 40 VCD buffer just fine for SVCD when multiplexed
I hope this helps anyone with a Panasonic RV32
-Phibertron -
Friends of our borrowed my SVCD DVD conversions but it didn't work on their RV32. I'm sure that's their model. I don't think I'll bother changing my process just for them. Thankfully standard SVCD production works fine in my Philips.
scottb721
You don't have to change your process for them
They could borrow your SVCD and make there own
They would just have to extract the mpeg with VCDGear or IsoBuster,
Demux the mpeg into .m2v and .mp2 , and Re-Mux back together
Then they could use VCDEasy or Nero and burn there own SVCD
Also, They could try the VCD Header trick
Its all about options, no one has to do anything,
but if they wanted/needed to get something done,
its better to have options to do so, than to not have any.
Phibertron -
You can perform the VCD header trick with TMPGenc Mpeg Tools or with BBMpeg
With either programs you have your .m2v and .mp2, the .m2v being mpeg2,
and you mux them as a mpeg1 non standard in tmpgenc,
and as vcd with bbmpeg
The RV32 thinks it is seeing a VCD and plays the SVCD file normally
-Phibertron -
Perhaps I should do this from now on with my own disc even though my Philips plays SVCD's fine.
Mainly for compatibiltiy with other peoples players as any future purchase of a standalone for myself will included a test with one of my SVCD discs before purchase.
Thanks for the info. -
Hi Philbertron, looks like you're the expert for Panasonic DVD RV32. I'm trying to make SVCD for a friend who lives in the States (I'm in Singapore). My files are mpeg2. Must I make the SVCD using header trick or will the standard SVCD play without glitch?
Look forward to your reply,
HalleySoftware:
Adobe Premiere Pro - capture stills & motion, edit, render
Adobe Photoshop 7.0 - edit stills
TMPGenc Plus 2.5 - encoding, splitting mpeg
VCDEasy 1.1.5 - stills to mpeg, interactive menu, SVCD cue/bin
MOTV 2.10
Nero 5.5.8.2 - burn image -
Halley
I'm no expert, I just did lots and lots of reading, with a lot of trial and error
You have 2 choices
1.
Create a SVCD that has its mpeg2 muxed according to my above post with bbmpeg
2.
Create a VCD with the Header Trick
You could always create one of each, and send them both
-Phibertron
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
Panasonic DMR ES46V Remote Won't Work
By melvid in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Sep 2009, 18:57 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
Will this hack work on the Panasonic DMR-EZ475V?
By Fretbuzz in forum DVD & Blu-ray RecordersReplies: 6Last Post: 8th Oct 2008, 08:21 -
panasonic dmr-es46v doesn't work
By Delreek in forum DVD & Blu-ray RecordersReplies: 7Last Post: 28th Sep 2007, 05:25
